Necromunda Adding gene smithing on yak
Wardys Revenge
Sep 7, 2021
Hi all,
Not to sound daft ,
But where is the option to add gene smithing on yaktribe during Goliath creation? Or do you just create the ganger then manually change the stat?
Hi all,
Not to sound daft ,
You add it after you create the fighter. It’s under ‘equipment’ 👍🏻
Hi All,
i have added, The Tyrant's Own but I cant work out how to apply the 2 upgrades.
need some help people
thanks
Reactions: YerDaddy
I've bumped into the same issue. Is the solution to simply modify base stats? (Seems a bit strange to include the rows for specific upgrades if they aren't used)
Reactions: YerDaddy
As the tools currently stand, yes. The genemods that need manual adjustment of stats are presumably still in the equipment list because they contribute to the cost of the fighter.
Hi I am new to this I cannot see any gene smithing option in the equipment section for Goliath at all??
