Pretty much anything should work. The snap-fit 40k cultists are fine, though not always the easiest to weapon swap.
One approach is to say that your cultists were formerly regular members of a house before they turned to chaos, so you could simply start with whichever Necromunda models take your fancy and convert them with spare chaos bits, spikes, and paint schemes to show their new allegiance. While Cawdor look a bit more like your generic cultists, there's no reason you can't have Goliaths who've turned to Khorne, or whatever.
Another approach is to use whatever spare bits you want from other ranges, including Imperial Guard, AoS Empire models, Blood Reavers, Kairic Acolytes, Dark Eldar, etc (all things I've seen before). There's no need for them to look particularly coherent. If you want, each model can be a unique mutant-type thing. That also gives you scope to include (parts of) Beastmen, Orcs, Lizardmen (Seraphon), Kroot, or whatever else you have to hand.
