AOW:Planetfall - From in silico to tabletopico
Wasteland
1,061
1,283
123
Germany
So I have recently done my first tabletop game based upon the video game Age of Wonders: Planetfall. Pictures of the armies are included in this post.
And now to the main characteristics of the game explained in ten bullet points:
1. Usual army size is six units as it represents the maximum amount of units you can put in a "stack" in the video game though you can always add more if you so please. The game uses alternate activation.
2. Infantry is usually represented by being mounted on 5-man squad bases although there are exceptions to more special units such as snipers.
3. Units are grouped in Tiers with the exception of commanders/heroes in command squads who are a special case:
Tier 1 represents the common grunt of the faction.
Tier 2 includes either specialist infantry such as snipers, smaller mechanical walkers, bikes, etc.
Tier 3 features battle tanks and other models of the same size. Infantry who fit in this category need to be exceptionally dangerous.
Tier 4 has the largest models available for AOW: Planetfall and would include massive models such as Baneblades or Imperial Knights from GW.
4. The game runs on a D100% engine which determines hits, grazes (superficial hits) and misses. In some instances there is even the possibility of scoring critical hits but this is reserved for specific unit mods or exceptional moral values.
5. Everybody craves a specific dice set which is linked to their army´s colour scheme and this one is no exception. You need a dice set for this game which include a single D4, D6, D8, D12, D20 and two D10 (one of them indicate the tens when rolling for D100%).
6. All ranged weapons start at 90% hit chance at up to 3 inches (3 inches are the equivalent of one hex in the video game) and then degrade in increments of either 3 inches in most cases or in the case of sniper rifles in a less severe manner. A few examples: Rifles have a range of 21 inches (7 hexes), pistols 15 inches (5 hexes) and sniper rifles 27 inches (9 hexes).
7. Units have a Health pool and become worse, if they lose at least 50% of their Health. This instance is termed "Bloodied" and it reduces their damage output. This means you never remove models individually as in other wargames though you can indicate the "Bloodied" state by removing one part of a 5-man squad base if it consists of two separate bases (one part has place for 3 models and the other one for two models).
8. Models in a unit are all equipped in the same way like in the Horus Heresy from GW. Although I am working on a solution to squeeze in a few specialists and a sergeant for an optional rule as most players would want to use the squad they have built for 40K.
9. The game includes a suppression system which is based upon "High Impact" hits such as basic grenades and sniper rifles and "Massive Impact" which are caused by either bombardments represented via Stratagems or high-tier weapon mods.
10. No game is complete without a morale system though funnily enough AOW:planetfall had only a very rudimentary version in which specific debuff effects of abilities could lower the morale of units but simple casualties would never cause units to run away. I changed that with my "Tug of War" mechanic. It goes like this:
When a unit becomes "Bloodied" (loses at least 50% of it´s Health) then the morale of the army drops from Zero (default value) to -50. Should this unit be later wiped out then a further drop of 50 morale points occur.
Should the unit be wiped out in one go without having time to become bloodied then 100 morale points are lost in that way. Should then a unit of the other army become bloodied the "Scales of Carnage" will tip into the other direction.
So if Army A lost a whole unit (-100 morale penalty) and Army B scored a single "Bloodied" result (-50 morale penalty) then in total Army B would be regarded as having a malus of -50 morale and Army A would be regarded as having +50 morale. A minimum morale of +200 is required for having a chance of critical hits and a minimum of -200 morale is required for having a chance for fumbles.
Rout tests start to happen when an army has at least accumulated a net negative of -150 morale and the morale value of a unit is based upon it´s experience level (Recruit, Novice, Veteran, Expert and Prime) and Tier (1-4).
Pics of the armies:
Lost Cargo - An AOW:planetfall scenario
Background:
Two armies, the respective expedition forces of the Iron Empire and Nurgle Legion, have found a cache of containers with useful loot to jumpstart their colony on Karrion Sands which is a remote desert world filled with bandits and dangerous wildlife on the outskirts of civilization.
Winning condition:
The army which has the most units of the type "Infantry" and/or "Heavy Weapon Team" in three inches distance to any one of the containers at the end of the game wins this scenario. In case of a tie then the army which scored the most victory points wins the game. The game is automatically over if one army routs or concedes.
Special Rules:
1. Random Game Length
The game takes five turns. Then a roll of 3+ on a D6 indicate that another turn is being played. After that a roll of 4+ indicate that a seventh turn is being played. And after that a roll of 5+ indicate the last turn of this scenario.
2. Handle With Care
The cargo is valuable and easily rendered useless by careless damage. As such armies may not use weapons with the "Explosive" trait such as basic grenades when they fire TOWARDS the containers at nearby enemies. However units positioned nearby containers may fire those weapons into the outer perimetry.
Armies (500 points):
Iron Empire (Secret Tech: Osirian)
1. Commander with Caustic Blade (Tier 3 melee weapon), Imperial Pistol and Basic Grenades. She is accompanied by a Field Medic, Radio Operator and Standard Bearer. Unit mods: Ankh of the Underworld.
2. Reapers with Beam Rifles and Basic Grenades. Unit mods: Ankh of the Underworld, Ignition Modules and Nanite Injectors.
3. Iron Storm with Beam Rifles and Basic Grenades. Unit mods: Ankh of the Underworld, Ignition Modules and Interlocking Armour.
4. Snipers with Imperial Sniper Rifles. Unit mods: Ankh of the Underworld.
5. Heavy Weapon Team with Gatling Gun. Unit mods: Ankh of the Underworld
6. Trike with Machine Gun and Bike Cannons. Unit mods: Ankh of the Underworld.
Nurgle Legion (Secret Tech: Nurgle/Ruinous Power)
1. Commander with Imperial Pistol, Laser Sword and Basic Grenades. He is accompanied by a Field Medic, Radio Operator and Standard Bearer. Unit mods: Cloud of Flies.
2. Traitors #1 with Beam Rifles and Basic Grenades. Unit mods: Cloud of Flies and Ignition Modules
3. Traitors #2 (painted in dark green) with Beam Rifles and Basic Grenades. Unit mods: Cloud of Flies and Ignition Modules.
4. Heavy Weapon Team with Laser Cannon. Unit mods: Cloud of Flies.
5. Heavy Weapon Team with Missile Launcher. Unit mods: Cloud of Flies.
6. Battle Tank with Battle Cannon, Laser Cannon, Defensive Heavy Bolters, Ram and Smoke Launchers.
Battle Report:
Turn 1:
All units move in more favourable positions and in some cases deploy into cover which consists of groups of gigantic, spiked, desert cacti called lovingly "Spikers" by the indigenous population.
Turn 2:
The Reapers have moved into the centre of the board where three cargo container are positioned and are close to the blue container. They go into "Defense Mode" (makes them harder to hit but they can´t use any other active abilities such as using weapons). The enemy is shooting at them but at that point few opponents can draw lines of sight so that the damage they suffer is miniscule.
Traitors #2 move close to the blue container as well. Traitors #1, who are ona hill, are being set on fire by the Iron Storm because of their Ignition Modules grafted onto their Beam Rifles. Now they are burning and will suffer damage for three turns in a row and are easier to hit too (+20% bonus). The Trike has managed to flank the Commander, who is lurking behind his grunts, by having raced around the hill with breakneck speed but only scores minor damage.
Snipers have moved into a group of Spikers and deal minor damage to Traitors #2. The Heavy Weapon Team (HWT) with Missile Launcher destroys two cacti, injures the Snipers lightly and leave them wide open for the incoming Battle Cannon shot of the tank. Though that shot only deals superficial damage.
Turn 3:
Battle Tank rams Snipers for serious damage and now they have become "Bloodied". The burning Traitors (#1) receive now serious damage by the Iron Storm and the HWT with Gatling Gun. Trike does superficial damage to Command which caused 0 damage to the Reapers and the HWT with Missile Launcher moves out of cover to threaten the Trike in the following turn. The Snipers have accumulated three stagger tokens and clear them all now thus doing nothing the entire turn. The Reapers receive only light damage while still hugging the ground and activate at the end of Turn 3 to throw a Basic Grenade hitting Command, and both Traitor units, doing minor damage but placing a single stagger on both Traitor units in the process.
Turn 4:
Traitors #1 are being deleted by the combined fire of HWT (Gatling Gun) and the Iron Storm. HWT with Laser cannon misses it´s shot at the Iron Storm and the Command deals again 0 damage against the Reapers and the latter is again being hassled by the Trike dealing moderate damage to them. The Reaper respond in kind and deal serious damage to opposing Command as well as setting them on fire with their Ignition Modules. HWT with Missile Launcher only deals miniscule damage to Trike.
Traitors #2 are being charged by Command but the attack misses. They pull out off melee, get injured in the process by the attack of opportunity and light the Reapers up on fire with the help of their Ignition Modules.
Snipers back away from the tank at deal moderate damage to it. In response they are being rammed again for very serious damage and thus are close to being removed from play.
Turn 5:
The Reapers receive moderate damage from HWT with Laser Cannon. The Reapers use their Nanite Injectors which heal 15 Health points and leave them with a single action point. They use this action point wisely by dealing moderate damage to enemy Command. Iron Storm moves up and deals serious damage to Traitors #2 and the upcoming volley of the HWT with Gatling gun leaves them with only 1 Health!
Command of Nurgle Legion uses the Field Medic to heal 30 points of damage, uses the Standard Bearer´s Rally ability to ignore morale debuffs for two turns and charges with the remaining action point the Trike which has previously come very close to them and it suffers moderate damage by the charge. The HWT with Missile Launcher shoots again at the Trike and cause miniscule damage. The Trike disengages, suffers minor damage in the process and causes moderate damage to the enemy Command.
The Command of the Iron Empire charges the HWT with Laser Cannon and deals significant damage.
The Battle Tank rotates on the spot and deletes on one side the Snipers with the Defensive Heavy Bolters and with the other sponson it deals moderate damage to the Reapers.
Turn 6:
Trike deals a ridiculous amount of damage to enemy Command. Now it´s looking grim for the Nurgle Legion as the Standard Bearer removing the current morale buffs is gone. At the end of this turn Rout Tests will be need to be made. Battle Tank shoots it´s Defensive Heavy Bolters thrice at the Reapers but only deals miniscule damage. HWT with Gatling Gun deletes Traitors #2.
Iron Storm deletes Command by dealing lots of damage. Now it´s looking grim for the Nurgle Legion as the Standard Bearer removing the current morale buffs is gone. At the end of this turn Rout Tests will be need to be made. The HWT (Laser Cannon) receives moderate damage from Command and suffers now from "Debilitating Infection", an ability caused by the Caustic Blade, which will drastically reduce their morale (-400 morale) and will make them easier to hit by 20% for three turns.
End of Turn 6:
Reapers burn to death by having only 2 Health left and suffering 5 fire damage.
The HWT with Laser Cannon failed their morale test but could not run away by being staggered in melee. The Battle Tank routed and sped towards the table edge. The HWT with Missile Launcher succeeded the Rout Test and another turn would be played but the Nurgle Legion wisely conceded at that point.
Conclusion:
The units felt like bullet sponges because dice rolls were made which were substracted by the armour value. As such results were very swingy. To more simulate the feel of the game and add more lethality to it damage dealt will be maxed by hits on every occasion apart from Grazes of course. Dice rolls will only be made, if the target has any kind of cover to represent some of the shots being absorbed by it. The morale system needs a bit of finetuning as well. I will upload the pics of the battle report in the following days.
