For a future campaign one gang i am running will be my Proton Skulls Van Saar
I am considering a archeoteck in the mix starting with weapon smith to remore Scace traits and add Plentiful to Non Scace weapons.
The plan is slog on to get enough XP to get a Gadgeteer skill Which allows Plentiful Weapons to gain an number of Traits. (Both Skills apply to some or any of the fighters weapons.)
The skills also mention weapons not spercifically Ranged weapons so can be appled to Melee ones.
Eventually I plan on the Spider Rig, make it Plentiful via Weaponsmith then either a Pulverise or Rending with Gadgeteer.
Which trait would you recomend?
Also I might splurge on Digi Lasers if extra rich (All fear my laser fingers!!!!) Hitting should not be a real problem (4+ is ok and can always be boosted by assists and eventual WS upgrades).
With S1 Digi lasers you would need 6s to wound regard so would you recommend Rending, so If it wounds it is D2 or Shock which automatically wounds but at D1 on a hit of 6?
(THe digi lasers part is mostly theoretical but potentially throwing 10 additional close combat dice to a charging spider rig is appealing, super expensive, from a psycological factor. One opponent is Delaque. They may have Shenanigans so might I Mwahahaha)
Seriously though I know it seldom gets Van Saar far but I don't send non neoteks galavanting up field. Opponents come to me to smash my puny rad phaged bodies. I'm thinking a more melee based Van Saar will be like a defense monitor. Slower so opponents come to them, but hit pretty hard (I BFG and Dropfleet as well).
. With the high attacks my Tyrant will head towards a melee primary focus so will end up getting close so thier ranged power will not need to be long range hence the shorter ranged shotgun. (Plus it looks cool as F).
