N18 Ash Waste Nomads
SirWalterManny
Aug 9, 2015
256
299
73
Sunderland, UK
Also not played with, or against, Ash Waste Nomads. Not sure how they ‘feel as a gang yet, but they seem to be a fast gang with both okay close and distant threat.
- I’ve skipped on prospects initially as don’t expect to be playing much Wastlands scenarios initially.
- Leader using Leadership skills; I generally never go for ‘Overseer’
- Usully try and armour up Champions, but opted not to and help squeeze in both a heavy (no suspensor yet, so will be a priority purchase from trading post) and special weapon, which normally rarely start with.
Kha'tragi Chieftain (Leader) {170}
- Blast pistol, Stalking Knife
- Mesh Armour, Ash Cloak, Sky Mantle
- [Leadership: Iron Will] (-1 to bottle roll)
Naku'taari Watcher (Champion) {255}
- Charge Caster
- Ash Cloak, Sky Mantle
- [Shooting: Trick Shot] (reduces cover modifiers)
Naku'taari Watcher (Champion) {130}
- Long Rifle
- [Shooting: Bring it Down] (action, friendly fighters ignore priority and re-roll to hit target)
Tarn'Runi Warrior (Specialist) {185}
- Web gun
Tarn'Runi Warrior (Ganger) {75}
- Blast Rifle
Tarn'Runi Warrior (Ganger) {85}
- Blast Carbine
Run'Taani Dust Runner (Juve) {45}
- Scavenged Stubgun
- Ash Cloak, Sky Mantle, Rocket Pack
Run'Taani Dust Runner (Juve) {55}
- Scavenged Stubgun, Blast Pistol
I've been playing the nomads in a fan made ash wastes campaign, so a somewhat different environment to what you're envisioning. I would say that I think this list might struggle if there are a significant number of T4 models in a campaign with it. I'm playing against both squats and goliaths, and I've found the chainlance invaluable. On the chieftain, it makes for a terrifying charge.
Yes, that’s fair. Has happened because of my reluctance to take unwieldy melee weapons, but in this case Chain Lance would on average do more damage against anything above T3 than the current blast pistol and stalking knife and the Versatile trait offers an extra advantage.
There are a few options against T4 until have chance to hit Trading Post: web gun for short range, and Charge Caster/Long Rifle for long range. Not sure what to cut to find the extra 35creds for chain lance.
Interesting you're skipping on the prospectors and the stormcallers. We're using Mounted units in every senario. I sometimes can't field them though if the objective is up a ladder. Worth looking into as fighter types though and what you can do with them. There's a perticularly nasty combo you can pull off if you're good with your positoning but you've really got to be on it in terms of where you move. You take Overseer on your Leader then use that to allow your two storm callers to reduce the visiblity down to 12" on the first turn then you just activate a single stormcaller on the next turn to set it down to 6" in the next turn. Then it's just a case of taking versatile lance weapons on the Prospectors and you basically papercut enimes to death with strenght 6 attacks though ridebys running in 8" and then hitting with versatile from another 2" and then running back out. Really at that point the only thing that shuts you down if you positon well is flamer templaes and other versatile weapons.
I'm considering my list for a new campaign after the last one petered out, and my conclusions from half-a-dozen games are that the stormcaller is basically wasted if you don't 100% commit to visibility shenanigans and the prospects are the best thing on the nomad list if you're gonna be in environments where they can move. The problem with the visibility game is that it totally shuts off your long rifles, so it's bad if you're on a more balanced list.
I would not call stormcallers a complete waste without the visibility option but it is a major feature of them.
In regards to T 3 and 4 points for ash nomads it is not as big a deal as you would think for the Nomads. Thier basic rifles and pistols, blast pistols carbines and rifles, all have Shock. They are relatively cheap weapons so you can have a fair number of them so those 6s will turn up automatically wounding regardless of toughness.
Check out the site Max Mini Desert Dwellers models. They have a good model for a Heavy Blaster and a Web gun or Venom caster. Plus some alternative desert robey fighters.
As Lunacruiser said - it seems you can do a lot with, err, a lot of little where Nomads are concerned. Not quite horde but... maybe a cloud. A wee crowd of Runners and Warriors zipping hither and tither with carbines (I've used some of the middling Ad Mech weapons - infiltrator guns, Vanguard carbines, phosphor serpent as etc) , blast rifles etc seem to work well.
Then it's just leveraging Stormcallers to "boost" things, and Watchers/Chiefs to really do the "tricks" that the rest can't (deliver Webs, damage etc)
I've had some luck with my infiltrating Chief (campaign lets us swap weapons, but no TP for first 3 rounds) - started with Blast Pistol, Long Blade and Displacer Field, quickly got enough doodahs and whatnots to afford a partial servoharness, chain lance and monohook.
Basically, the leader is doing interference, playing a cat/mouse "What's going on with them?" dance, whilst they try to to pounce on vulnerable opponents ("now you see me" tactic helps there).
The rest of the gang are shooty to a greater or lesser extent, a few with long blade and pistol, but the big value has been:
-Watcher with Web Pistol & Reclaimed Stub Gun (so a webber would be ideal, in hindsight)
- Juves with Carbines and Blastrifles.
Really, I think the volume of bodies and fire has been the key. Let's us to a bit of pinning and placent/board control, but then the odd "guarantee" weapon, like a webber, which is fairly sure to do what you want at least once if you can line it up "just so" is very good indeed.
Same with the pouncing leader - it's not a death maiden or nacht ghul, but you can do lots with the flexibility. Especially when backed up by a couple of long rifles and a runaround of Carbines and Blastrifles zipping this way and that.
Stick infrasights back on them :)
