N18 Ash Wastes Nomads Starting List - Underhive/Dominion
Darkwandarer
May 19, 2024
7
12
About to launch into my first actual necromunda campaign after playing a bunch of skirmish games. Will be SM/ZM boards.
We've agreed Sky Mantles will have work in the underhive - and have a 9" Visibility range for shooting.
Also, they are letting me hold territory as if I am an outlaw outcast gang rather than raiding.
We are not using Gang Tactics cards.
I put together this list - I really wanted to get the Duneskuttler in and a Web Gun Watcher as it's likely to be up close.
Chieftain, Mesh, Chain Lance, Overseer (190)
Watcher, Mesh, Web Gun, Hipshooting (240)
Watcher, Mesh, Long Rifle, Bring it Down (145)
Specialist, Blast Carbine (85)
Runner, Autogun (45)
Runner, 2x Stub Pistol (45)
Runner, Stub (40)
Duneskuttler (210)
be interested in opinions on -
remove Overseer for Infiltrate and swapping the Chieftain to a Web Pistol/Long Blade.
We have discussed Overseer and folks think it's a normal part of the game.
Swapping out the Web Gun on the Watcher for a Carbine or Long Rifle, take Fast Shot or something and getting a sight for them or armour for the Specialist.
Cutting the Specialist and having 4 Juves armed more like this:
Runner, Blast Carbine x2
Runner, Autogun/2x Pistol x2
Is 8 bodies enough or too many?
Am I over-valuing the threat to deal more than 1 damage per model? This is why I'm staying away from Blast Rifles, I could just be very wrong here.
Wasn't impressed by the Charge Caster/Heavy Blaster without a Suspensor especially in ZM, I think I get more bang for my buck with the Web Gun? Especially without Tactics cards to move it around.
This might be totally irrelevant now, but I reckon you can par the Juves back even further and just give them a stubgun. That way you can field more of them or kit our your big hitters more. The 2+ at short range makes them a real threat. Especially with high volumes.
I ended up going 6-0 with basically this list, ended up with a LR on the specialist at creation and just Stub Guns and hope for the juves.
The Duneskuttler/Web Gun/Overseer thing is too good and I wouldn't do it again.. but if anyone bad mouths the Nomads and you fancy proving they're definitely not the worst gang going..
Use this list. Deploy the three together out of line of sight and suddenly you have a Duneskuttler that can move 12 and charge 5+d3 or a Web Gun than can either move 20 and fire twice or move 20 and drop a template. Either way - I've had my fill of it.
We're playing 6 + 6 so about to start takeover and I'm considering rerolling or something.
Really looking forward to the new book.
Funnily enough I've landed on a very similar build independently of you! I've found any build that can bring a brute early on is usually at an advantage, because people generally haven't noticed that the new rules allow that.
Agree, the new rules will add a lot of new twists. Will be interesting to see if the Hunters are worth it in the Hive...
