Tiny bit more work on the Bat earlier, but I was mostly sidetracked. My girlfriend found a bag of old plastic Squats I'd lost in a cupboard. I paintstripped, disassembled, rebuilt and converted them, and lo! Behold! Squat Ratlings. Squatlings?
The non-original arms on the squad leader are from Empire Militia.
Mostly sharing here as I figured the sniper rifle recipe might be useful... OK, the sniper rifles are boltguns with the magwell and pistol grip removed, with various diameters of styrene rod and tube and a little green stuff added. Some swearing whilst waiting for polystyrene cement to stick barrels to receivers and attempting to keep them true!!!
I quite often adapt one weapon into another. I figure Imperial Manufactorums would use common receiver design cues across weapons, much as real world arms manufacturers do. In this regard I think the bolter receiver works here. When painted up it'll not be so starkly 'bolter with bits on', as the steel paintjob will blend the parts together. The offset scope is based on some real world ones, but mainly so the two aiming dudes can actually look down the scope's tube! They can also use the iron sights on top for quick close-range target acquisition. Tacticool!
Now I have six more to make up... ugh, more tiny-bits-of-styrene madness!!!
