@The Duke - Yeah they're a bit Ogryn-sized as I did them in a rush but they help it feel 'lived-in'. The muddy footprints run up all the ladder rings too.
The orange bits are from HP printer cartridges. They twist off the top of each ink, three small ones for CMY and a larger one for black. I've been stashing them.
Aha, I knew I recognised them, good shout @Xavier Bacon - they work really well!
Thanks @The Duke
I'm thinking my 'old school' should be a Cult Limousine? I could make something chunky enough to be a counts-as Goliath in 40K, and also scenery for a Necromunda or Shadow War skirmish. Whaddya think?
Other shots of Bryan Ansell's Limo here:
http://eldritchepistles.blogspot.co.uk/2013/06/bryan-ansells-genestealer-cult.html?m=1
I can use these to help draft a plan. I'll add more detail than the original and try to bring a little of the modern styling in. I won't use a base toy like the original, no sir.
Goliath is apparently 5" long, 2 1/2" wide, 2 1/4" tall. Mine will likely end up longer and/or a bit shorter, have to see what I can do.
I'd quite like to make it flat-bottomed so I can have a go at casting up multiples. I could do this by having separate wheel or antigrav units that glue under the wheel wells, or just go for a two-part mould. Dunno. We'll see how I get on
The joy of new lack of Fire arcs means I don't have to worry about replicating weapon placements. I can do grille- or hood-mounted guns just fine.
