Hi,
Trying to learn the rules.
I'm stuck on Las Cutter profile for Slave Ogryn gang. Its a 'Melee' weapon that has the 'Versitile' trait, and a number in the 'L' range. So presume I can use it up to that range in close combat?
The thing that's really throwing me off is it has a Ammo Roll number too?
So I guess my questions are, can it be used multiple times per activation, i.e. up to the amount of attacks the model has on its profile, and also do I have to roll an ammo check each time I use it?
The other basic question I have is...
In the Dominion Campaign, how many territories does a gang start with. Is it 3 each or just 1?
Thanks.
Thanks.
