I would absolutely encourage using older Goliath models as Unforged or Juves and Prospects!Might as well give the fighters that -1T/S gene-smithing defect to explain their smaller sizes![]()
I would like to warn new players that this article is very out of date, as heavy weapons and Juves (and much more) are now available to Goliath gangs, and they can buy lasguns from the trading post if they so wish. It's still good for size comparisons though.Base sizes are not mentionned anywhere in the rules.
People who insist you use 32mm bases will probably also point out that OG Goliath miniatures are way tinier than the new ones, which makes just as much of a difference as base size.
More importantly, some old miniatures wield weapons that are no longer legal under the latest iteration of the rules. For instance, a Goliath ganger can no longer wield a lasgun, an autogun or an autopistol.
While goliaths can absolutely buy lasguns that is very different from being able to use them. With the release of house of chains back in 2020 all your gangers and Juves were list locked for weapons (no goliath fighter has list access to lasguns) and prospects can only branch out for pistols and cc. Equipping lasguns to your champions is a good idea for a back up weapon but I certainly wouldn't make it a primary which is what you really want to modelI would like to warn new players that this article is very out of date, as heavy weapons and Juves (and much more) are now available to Goliath gangs, and they can buy lasguns from the trading post if they so wish. It's still good for size comparisons though.
I absolutely temporarily forgot about the Ganger weapon limits in House of ChainsWhile goliaths can absolutely buy lasguns that is very different from being able to use them. With the release of house of chains back in 2020 all your gangers and Juves were list locked for weapons (no goliath fighter has list access to lasguns) and prospects can only branch out for pistols and cc. Equipping lasguns to your champions is a good idea for a back up weapon but I certainly wouldn't make it a primary which is what you really want to model
Yes, 100%. I suspected that the Genesmithing probably was designed to allow for those who had older models to use.I would absolutely encourage using older Goliath models as Unforged or Juves and Prospects!
However... I do concur that unmodified mixing of ranges looks weird. So I’ve got my older ones and newer ones as two separate gangs.If you like them vintage Goliath's, use them! It turns out there ain't no GW secret police force. Base sizes? The difference between Goliath's old 25mm bases and new 32mm bases, is a 3.5mm charge range.
Be aware, though...The new Necromunda models are better than the old ones. A lot better. I have tons of the former (all painted and properly based). Over time, I have replaced them with new ones (all also painted and properly based). Resistance is futile. I use the adorable old ones for Juves. And, I don't use Juves all that much. I use my beloved vintage Savvies for Hive Dwellers.
Yikes x 90! Aside from the facts the older plastics are "less than select," (and most of the gangs in our group never bother with Juves; even free ones)...THIS is dedication! Respect.I have however converted 90s plastics to modern Juves and they look fine. Real “small man syndrome” going on there quite fits with their new title of bullies.
Yep... plus I got 12 cheap off of eBay!! Haha.Yikes x 90! Aside from the facts the older plastics are "less than select," (and most of the gangs in our group never bother with Juves; even free ones)...THIS is dedication! Respect.
