Necromunda Can't change ruleset in settings
alksdfasdfasdf
Sep 15, 2024
Hi, I'm new here. When I go into settings, (gear icon), it shows the ruleset as N18 (necromunda 2018). There is a checkbox next to it, but when I click it a popup comes that says "could not update setting." There is no dropdown menu there to change to other rulesets either, but my friend showed me on his device and he has this setting. This is outside of my individual gangs I've created, it's the global setting that won't let me change for some reason.
Has anyone encountered this? Any ideas? Thanks.
There's only one rulest available in the "new" rules (Necromunda: Underhive), which is why you can't change the tick box. If you want to use old school rules then you use the other tool set (Necromunda, with the classic box art). Then you will have options of Original Rulebook (ORB), Living Rulebook (LRB), or Necromunda Community Edition (NCE).
N18 settings:
Original game settings:
Reactions: cardyfreak
Think of the nightmare of options we could’ve had though! 😱
  • N17 Underhive+Gang War
  • N18 Hardback +GotU
  • N20 N18+House Books
  • N22 Ash Wastes
  • N23 Core Rules+House Books.
  • Wow
Reactions: Stoof
I'm not up to speed with the current rules, but I believe the issue is still the same as before - there's only one N18 ruleset set up here and it cuts off somewhere around Ash Wastes. Anything beyond that isn't implemented as a template but you can still custom build gangs by disabling restrictions and playing around.
If you need tools that are (mostly) up to date with GW's rule bloat then I suggest checking This Thread where the various online tool systems are compared against each other for some pointers.
Thanks a lot for the quick reply! That makes sense now – I’ll try the custom build option and check out the thread you mentioned. Really appreciate the help!
Reactions: Stoof
