Question Cawdor Help
RobinMalleus
Oct 22, 2022
Working on crafting up a test Cawdor gang, and I don't see a way to add Exterminators to weapons (such as a shotgun or a chainaxe) in the gang manager. How do you do this?
It is under under Equipment, Ammo.
If you do not see it then you are in the Necromunda(N95) section of Yaktribe rather than in the Underhive Tools(N17+).
Start a fresh Cawdor gang in the Underhive Tools(N17+), or start a Redemptionist gang in the Necromunda Tools(N95 / Oldmunda).
Thanks! It wasn't showing up under Ammo for some reason, might have just been glitching out on me (as I was using N17+)
N17 has Cawdor and Redemptionists being basically one big mixed list, however only fighters with more fanatical flavour can use exterminator cartridges…
Exterminator cartridge attachment.
❌Word Keeper (Cawdor Leader),
❌Firebrand (Cawdor Champion),
❌Brethren (Cawdor Ganger),
❌Bonepicker (Cawdor Juve),
✅Redemptor Priest (Redemptionist Leader),
✅Deacon (Redemptionist Champion),
✅Brethren (Redemptionist Ganger),
✅Zealot (Redemptionist Juve).
Only slightly confusing 🙄🤣
