Cawdor starting gang
I also think you're a bit short on bodies and ranged firepower. Try and get at least one more ganger preferably with a reclaimed autogun, ideally two. There are several areas you can make savings, the champs don't need axes and the photgoggles are probably unecessary for a starting gang (I assume it's so he can see through the smoke grenades). I quite like your leader as he's a bit more interesting than just sitting back with overseer.
The second long rifle is nice but I think you'd be better off with a cheaper weapon and more bodies. Perhaps give the leader frag grenades for his rats too.
thanks for your in put, I might look into adding more range and maybe a ganger more, but I see no reason to get more than 10 guys, as most missions cap gangs at 10 models
my plan was to run the leader and ganger up front in cover of smoke and my long rifles and crossbow givning shooting support
What are you planning to use for the long rifles? Not sure what parts to use for them.
I will use the leader body for the champion with long rifle.
The pole of the Icon will be part of the barrel, at least in theory
I am planning to fully convert the leader with GSC legs and bretonnian infantry body... with a little help from somebody who know how to sculpt a little
I am assuming that the Cawdor are intended to scorch their way along the battlefield right? The rules for flamers and "Burn" sound pretty gnarly, and I am excited to test it out. Yet how to achieve that within 1000 credits I am unsure. I will try and take the advice here and implement it.
Reactions: Devilmixer
finaly I have finished my gang-setup, what do you think about this?
https://yaktribe.games/underhive/gang/ragnarök.29024/
we play 2d and 3d and the other gangs are van saar, delaque and orlock.
What do you think about the ganger with the two stub guns, would this be better then the autoguns?
when i earn the first mmoney i will buy smoke granads and a rat. any ideas for the champion skills?
greetings
Timson
PS.: sorry my english isn't so good
