chaos marine special rules
hummus11
Feb 6, 2014
6
Im gonna do a game thats based on a chaos hive world
Each gang will have 2 chaos marines
I will use the base stats from 6th ed 40k for their stats but was wondering which
skills they might start with
Weaponsmith
bio booster and other stuff like that
Dont start them with any skills, but make them immune to pinnnig
Also give them options to aquire marks at certain Exp points instead of a skill table for them
LRB
M4 WS4 BS4 S4 T4 W1 I4 A1 Ld8 300 Credits/150 without Power Armor, 160 +1W6 XP
Armour ()
Chaos Space Marines wear power armour which confers a 3+ saving throw. Power armour is neurally linked to its wearer so it does not penalise his Initiative like carapacearmour.
Juggernaught
If the model suffers a hit but isn't wounded by the attack then he may immediately take a Strength test. If the test is passed then the fighter ignores the hit so won't be pinned either. Note this can allow the fighter to continue his move if attacked from overwatch.
Rapid Fire - Bolt Weapons
True Grit
CE
M4 WS4 BS4 S4 T4 W1 I4 A1 Ld8 250 Credits/150 without Power Armor, 160 +1W6 XP
Armour. Chaos Space Marines wear power armour which confers a 3+ saving throw. Power armour is neurally linked to its wearer so it does not penalise his Initiative like carapacearmour.
Skills: Rapid Fire, True Grit, Juggernaught
First off I was wondering do marines really need to be in the under hive?
And after seeing your rules I think they are ok. I wouldn't mind seeing a gang of them in the under hive either. But I need to know why would they be there to start with?
Also I think it would be worthwhile having a champion that acts as the gang leader.
Something like:
WS4 BS4 S4 T4 W1 I4 A2 LD9 350-400 credits
Make it so the gang must have 3 members so they essentially start with 3 models.
Tho how would they acquire equipment or credits, how would they recruit new members?
i would think that the chaos space marine gang could recruit traiter guard or cultists.
Or maybe it could work as a tyrant gang where like the forge world army there is one chaos marine and all the other members are his servants.
Alternatively a squad is scattered across the hive world and trying to find each other before they can leave. Recruiting a new member would count as if they tracked down a previously lost battle brother or whatever...
Something like:
The idea is either part of the hive is teleported into the chaos dimension and ends up on a chaos planet
or part of a chaos world is teleported to an underhive somewhere in the galaxy not nessecarily to Necromunda with a stalker the video game vibe having monsters and artifacts involved
