Hi all,
New to Necromunda but have now played a lot of games. We're still struggling to understand the charge mechanics.
It says under "movement" (page 61) that models must take the shortest possible route.
We're not sure if this is designed to prevent charging multiple enemies and/or prevent charging past then into the back of enemies (to use skills like backstab).
At the moment we're playing as though you must move via the most direct route and therefore can't Engage more than 1 opponent (unless the model has a versatile weapon or whatever). However other parts of the rules seem to imply that models can charge multiple enemies. For example under "Charge" (page 58) it says "they must have sufficient movement to get into base to base contact with at least one enemy fighter". This implies engaging multiple enemies is fine, which suggests that you must move the most direct path but may use all your move as long as you end up engaged with at least one enemy.
Could the group please advise if we are doing it right or if the implied charging of multiple enemies is fine (and by association, the ability to move around the rear of an enemy to use backstab or simply force them to turnaround with excess movement).
Cheers
Cheers
