Charging over/around barriers
Azzabat
Jan 24, 2013
3,721
7,142
183
59
When you declare a charge against a model, do you have to run in a straight line? I.E. Ganger A is in cover behind a barrel/low wall, with a barrel/low wall to their left and right, but nothing to their rear. Ganger B is 5" directly in front of Ganger A. Ganger B charges Ganger A.
Does Ganger B charge 6" in a straight line towards Ganger A and take the -1 to hit for fighting over an obstacle? OR ...
Can Ganger B use his 8" of charge movement to skirt around the barrels/low wall Ganger A is taking cover behind, and charge them in the rear for no to hit penalty?
(Ganger A is in base contact with the cover/barricade)
Answers on the back of a Juve to ....
Reactions: Llewy
Without having the rulebook in hand:
I would say that you could choose to run around the barricade, but you would have to declare the charging route before measuring anything, thus running the risk of coming up short.
the great thing about necro is you dont have to charge in a straight line =D
Also barricade the are no more then 1" high and wide dont effect your movement
The rules don't actually state anything more than an 8" charge range. My view would be that you'd choose the most direct route as the longer you're charging at someone, the more likely they are to shoot you or get away. Also why else would there be a -1 to hit for a defended obstacle, if you were allowed to simply run around the side of the obstacle, or climb over it 1" away from your opponent while they sit and stare at you?
I suppose my view is colored by the bar fights I've seen where the combatants lunge at each other over the table/bar, when there has been ample room for them to go round the sides.
("Zulu's Sir ... bleeding 'undreds of em!"
"Well, you just stand there laddie whilst they run round the side of this chest high redoubt, then we'll fight them when they gets in 'ere behind us.) ;)
Reactions: Llewy
The only real restriction for charging is that you cannot charge hidden gangers. You don't even have to see them at the start of the charge, just know they're there.
Oh, we always play you'll have to pass an Initiative test to charge someone you can't see. Maybe we took that from Mordheim tho, but it makes sense to me, you can't just blindly run around a corner waving you weapon if you have no clue where or how far you're going.
Edit: Mind you this means non-hidden models you can't see. And within 4/8"
We play that you can charge over things if you have the movement for it, again no pre measuring
I do have issue with getting a "charge bonus" when models are very close
I also play warmachine (the charge bonus is a different thing in that game) the charge bonus only applies if you move more than 3"
I will likely put this idea forward for the next campaign we do
The rules don't say a straight line, barriers tend to only be an issue if you don't have the mover throughout a charge to get in to contact in a way that avoids the barrier or wall
TO be honest I think this is an oversight in the rules that leads to strange situations. I play that you have to charge in a reasonably direct line to your target because otherwise you can almost always position your charging model in a way that negates the 'defender behind cover' or 'higher up' combat bonus. For example if you have a defender on a staircase and the attacker is at the bottom, he can charge 6 inches towards the defender then with the last two inches he can go around him so he is higher up and getting +1 to his score.
Or a defender is behind a wall, so the attacker charges, hops over the wall and attacks the defender from behind.
Also it can lead to odd situations involving overwatch, where you charge in such a way as to be out of line of sight - say if you are 2 inches away from an overwatching model, but you charge a long way around into their back so they can't see you. Arguably this is just common sense, but in some terrain set ups it does have quite a huge impact on a game when this happens a lot.
It would be possible to say this is all intended - that it is not so much of a wild charge (or a charge in the Fantasy Battle sense) but more of a strategic move to get into hand to hand without being distracted by aiming or stealth or anything like that. But it still feels wrong to me when someone carefully hops past your defensive line to stand on a crate behind you and smacks you in the back of the head from higher up.
TLDR - Although it's not the actual rule, it makes more sense if a charge is always roughly directly towards your target.
Reactions: Llewy
Agreed!
Or maybe you CAN take an indirect route but loose your charge bonus?
I agree that a charge should be in as straight a line as possible. Thanks to Bruticus for putting what i was thinking into clearer words (I'm normally a plans and diagrams kinda guy)
I think if there is a low barrier directly in between you and the player you are charging the same 2" penalty for crossing it would occur, and if you charged through a patch of difficult terrain the 1/2 rate of movement across that terrain should apply as well. If you were right on the edge of difficult terrain where it would somehow be 8" or less to go around but more than 8" to cross (maybe if the difficult terrain was +4" in distance and the opponent was right on the other side) then I can understand running around, but the idea to run past someone and then attack them from the top of the stairs just sounds like a terrible tactic. Beardy. F^#k those people, I'd rather not play a game than have an opponent that tries so hard to manipulate the rules. There's no money in winning Necromunda matches.
I don't know how well this would work, but could not a rule along the lines of -
A charging model must declare his route before any measurements take place. It is up to the charging player to determine the route by adhering to the guidelines below.
A charging model MUST charge in a straight line to gain the +1 charge bonus.
In the event that the charger cannot charge in a straight line to the enemy (either due to obstructions or because the enemy is around a corner), the charger must take the next shortest possible route.
The charge bonus would then become a bonus for the element of surprise. If the charger must deviate from a straight line (for example to round a barrier) then the target would have time to prepare to receive the charger. The element of surprise is lost.
I can see that as being problematic though now that I think about it. It would probably cause more arguments than anything else. But if we remove the part about 'to gain the +1 charge bonus' then it's fairly explanatory.
He have 1" and less high cover items, like barriers and the like as being vaulted with no penalty. If you are able to vault the barrier to arrive at the side of the target, then you fight with the +1 as normal. If you are unable to leap the barrier, for example, there are two enemies beside each other covering one side of the barrier completely, leaving no way around the barrier (imagine a barrier midway across a walkway), then you fight over the barrier.
We also have ladder fighting, which I brought in after my other brother and I encountered it. It removes arguments and keeps the games flowing as smoothly as possible.
The way I do these things:
You must charge directly into combat unless it involves any risky actions like jumping in which case you are allowed to go an alternative route. You must declare the route you are charging before measuring, if you don't declare it is assumed to be the direct line to the enemy.
'Directly into combat' is defined as the shortest possible path that gets you into base to base contact (including base to base with a barrier in the way).
You can't fight while hanging onto a ladder as you can't end your movement on a ladder (house rule to avoid trying to blutack models to the sides of buildings). But you can jump off the last few inches into combat if you want (prevents people blocking the bottoms of ladders so you can't get down) and you can charge to the top of any ladder even if it is blocked by a fighter at the top (move them back slightly), but you fight at -1 for opponent being higher up.
You can't charge (or move) through any gap that your base can't fit through (so can't slip past people blocking a walkway). But you can charge right past someone to a target behind them if you declared it.
I would also be tempted to add the 'you must move at least 3" to count as charging' rule someone else mentioned as that makes sense to me.
I have also thought about adding the intervene rule from Mordheim - a single enemy model within 3" of your charge path may move into the charge path and intercept the charger. They count as being charged (so have -1). This would just be to stop people charging right past your gang into hand to hand with a heavy. It looks so odd when it happens. This only works with direct line charge paths.
Also I would note that it's not such a terrible beardy tactic to charge in such a way to get higher up bonuses - it happens all the time. Say you had a guy halfway up a wide ramp and you charge into him, would you position yourself lower down, on the same level or higher up? Higher up might be pushing it, but on the same level is probably what a lot of people would do. In my opinion it is common sense to do something like that, but it also is clearly not what should happen.
The higher up bonus and the behind cover bonus are so powerful (they are the same as charging, or an extra point of WS) that they should not have wriggle room in the rules, in my opinion.
I think you are all confusing straight line charges with other systems, such as fantasy and 40k.
Loosing the +1 takes combat out of the system and is less about combat and more about shooting!
Also an advantage of being charged is over watch too
It's not a case of being confused, but I think you have to admit the word charge makes you think of running right at the thing you are charging, you wouldn't expect to get charged by a rhinoceros (or triceratops) only to watch it run in a big arc, hop over a wall and balance on a barrel behind you.
I'm not sure what you mean by 'loosing the +1 takes combat out of the system' but if you are suggesting to get rid of the +1 bonus for charging I think that is a bad idea as it encourages strategic positioning so you can get a crafty charge in and even the odds against that h2h monster. Being behind cover and being higher up are clearly also meant to encourage strategic positioning, they are just too easily exploited.
The reason why straight line charging isn't possible is because its a skirmish game.
I have barely played a game where a model has been able to see further than its gun is able to shoot a target.
Terrain should be thick on your boards. For this reason you also don't need to be able to see or detect your target of a charge (unless they are hiding). That in itself feels a bit elusive but that's the nature of it all
jimjimjimmyjim said:
The reason why straight line charging isn't possible is because its a skirmish game....
I think most-direct-line charging is what should be implied, as well as maybe like a "closest distance possible", which, if there is a 2" diameter difficult terrain piece halfway between you and your opponent who is 6" away from you, then maybe going around it is just as close.
