My group and I may have found a rules hole last night and I would like some help with clarification.
The situation; Van Saar ganger is standing on a platform with his base partially covering the hatch above a ladder. There are 2 Escher gangers below waiting to Charge! On the Escher turn the Escher gangers attempt to charge up the ladder into HtH with the Van Saar ganger.
After some reading in NCE 2018, Moving (pg 10) says 'models cannot move through the bases of enemy fighters'. Charge! (pg 11) says the charging 'ends with the attacker touching the enemy base-to-base' and that 'models are engaged if separated by a low wall or obstacle.
My questions; is the Escher charge legal or is the Van Saar blocking the hatch preventing HtH as the Escher cannot reach base-to-base? Is it possible to block ladders and thus prevent someone from charging you?
