Combat vs Vehicle
Discussion in 'GorkaMorka' started by Dayve220, Nov 23, 2016.
  1. Dayve220
    Dayve220 New Member
    When unopposed on a vehicle you may attack it via shooting or chopping and will hit or strike automatically.
    However, how many times would you strike? how do you play this?
    Once?
    Once per attack? (+1 for two H2H weapons)
    D6+WS times?
    Ben_S and Flamekebab like this.
  2. Flamekebab
    Flamekebab Gang Hero
    Gorkamorka Warboss
    If I'm reading this correctly then it works like a normal round of hand-to-hand combat with the difference that the opponent has a combat score of 0 (page 44 of Da Roolz).
    So that'd be a number of hits equal:
    (highest scoring individual dice from: (number of attacks)*D6)
    +WS
    +modifiers (critical hits and fumbles being the main ones)
    Each hit being whatever Strength value is relevant (so it could be a mix of S3 and S4, for example).
    So it's quite possible to get ten S4 hits on a vehicle if unopposed!
  3. Knuffe
    Knuffe Juve
    Page 20 of da roolz. Shoting into combat. As i read it, you can shoot into a wheicle from the outside while close combat is going on. but you must count your own models as "their" crew when delegating hits. roll dice to share the pain.
  4. Flamekebab
    Gorkamorka Warboss
    But close-combat isn't going on. They're unopposed.
    That said - if you've got a warrior onboard then he does indeed count as crew so it's not a good idea for the rest of the mob to start shooting at the vehicle. They'll do it anyway though!
Share This Page
