Necromunda Creating an Outcast gang in Yaktribe with custom tool
Minotaurus
Sep 17, 2020
5
8
Hello,
I will be starting in a campaign with an Outcast gang based on a delegation and wanted to put the gang on yaktribe.
So far i have made custom gangsters to represent the members of the delegation, the hive scum and the hive champions and then put them in a custom gang but have several questions.
Is there a better way to do it?
Is there any way to put the arquetype or special rules a leader has anywhere other than notes?
How can you make a scum racer part of your gang?
Special Rules: You can make customs skills or equipment and add notes to the fighter card that way.
Hello,
1) pretty much how I am doing it.
2) you can create Custom skills for say Gang Hierarchy (Leader), and remember to unrestricted skills in settings then add them as skills (not Advances)
3) Scum racers are in the hired guns/pets section.
Reactions: Minotaurus
Is there a problem as when I am putting in the custom leader after set up it calls up as if stats for a vehicle?
Any advice help appreciated
For some reason it defaults new custom gangers etc to Crew even if you select the right option.
You can fix it by editing said custom leader and reselecting the Crew? No option again that will work.
Reactions: Pedrobedo
