Necromunda custom ganger don't work
pigiott8
Jan 26, 2023
5
11
hi. i try to custo an enforcer sanctioned pattern automata to my enforcer but custom ganger don't works.
when i save the data all become a veicle.
Try editing the ganger you created after you finished it. If you check the crew? No bit after you finish it it should change the entry to a normal fighter.
It's happened to me several times and that worked for me.
Pc or mobile?
When it's happened me I initially checked the box Crew. No
It decided to make it a crew anyway (Yo bro where's my vehicle or something).
While still in the Custom Ganger section of the Tools, edit the ganger you just made and change the crew box back to No.
That should make the fighter normal again
You can then add it to your gang.
Just ran a test ganger to check and it worked for me.
Pc or mobile?
both, pc and mobile. don't work. ater i create a cannot delete anithing
I fix the problemi tanks.
Now I try to create a weapon but stats don't appear on the tradingpost
