N18 Delaque campaign starting list 1000 credits
Jazzmaster
May 9, 2025
Hey,
i need some advice on my Delaque list for the first campaign im playing.
There are some houserules such as only one champion in the starting gang, only one special/heavy weapon for start (later 2 are allowed) and max 3 web/blaze template weapons.
I tried to squeeze in as many bodys as i can and now i have 65 credits left what should i spend them on or should i change some things equipment/character wise?
Guess i will promote one ganger to specialist even if he cant take special weapons at the moment and add a sidearm on the leader as backup when the plasma fails an ammo check.
There will be a second champion added later i will probably go for another nacht ghul and equip the specialist with a special weapon or should i go for another shooty champion?
Thanks in advance!
Since my initial picture seems to be too small and i couldnt edit the post anymore here another try.
If you can prep to get a second champ after game 1 that seems like a good plan, just to get another post-battle action, so saving the creds might be good, combined with the whisper merchant you'll likely get enough to kit them out.
Otherwise it looks good to me, nice variety in weapons, a lot of bodies. With so many fighters Overwatch might be good for you Leader. If you are feeling spicy you might want to drop two gangers and hire a bounty hunter with a heavier basic weapon like a boltgun, firestorm combat shotgun, or executioner shotgun to add firepower.
Reactions: Jazzmaster
