Hi,
Now playing Necromunda and need to buy the second box for Delaque gang.
We play very seldom and i will have something like 6-7 free bodies.
So have an idea to use Delaque models in killteam.
Which faction and units do you think Dealaue fits the best?
1) Chaos cultists, aka Alpha legion operatives.
I like the idea, armour is the same, a bit non imperial appearance, but...
a) Delaque models are higher then regular marines. So i would need primaris as csm, but if the opponent will have primaris it could cause misunderstanding.
b) cultists have quet boring load out.
2) IG, aka inqusition henchmen band.
For storm troopers i can use storm troopers's heads, get heavier shoulder pads.
The only question will regular delaque looks like regular IG troops(orlocks would fit better).
3) Genestaler cult aka neophites.
The problem again with their sizes. I can scratchbuild some acolytes or abberants with Alien like appearance, adjust the size with greenstuff a bit, but not sure if it feets well.
So what option do you think this models will fit?
