I would use a thin paper rectangle attached to a stick and hold the in front of a mini without moving anything. Would have to make 3 though, one for each basessize.
the old whippy sticks with a bit of blutac on the end would have been perfect for it.
Really you just want something that you can change the rectangles on.
Well, decent discussions suggest we would need up to 7...
You would only really need the ones that are relevant to your gang so unless you have lots of different base sizes and sizes models you will likely only need 1-3.
What would you end up with?
- 25mm small cylinder for small pets (lizard cats and cyber doggies)
- 25mm normal cylinder for all human sized fighters
- 25mm “flying” cylinder basically a double height cylinder with the top half being targetable for wreckers.
-32mm small cylinder for bigger pets (cyber doggies)
-32mm human cylinder for Goliath
-32mm flying cylinder for hoverboards and the psychic potato.
-40mm small cylinder for the biggest pets (sump krok sand phyrr cat)
-40mm big cylinder for brutes (zerker, ambot, etc)
To be honest though you could just get away with three actual rectangles sized for the large models and mark the smaller cylinders on them.
