I’m going to start this off again by saying that I currently lean towards allowing two pistols be used in close combat, even though it is not how I originally read it nor do I believe it is as clear cut as some people think it is.
In short this is a long winded agreement with an argument or a discussion on semantics.
This isnt the case. "A" and "One" aren't strictly interchangeable. "A" is also interchangeable with "Any", as well as many other words, dependent on context.
Agreed. I simply stated that they CAN be interchanged, not that they should always be used interchangeably.
That said I don’t think any is used interchangeably as often as one is, and even then the words one and any won’t contradict in most uses.
The word any also has significantly wider tolerances than the word a as any can be applied in both singular and plural while a is specifically singular.
"A" is not used to mean "One" in the close combat rules, as an example, the following sentence: "A fighter can use up to two weapons with the Melee or Sidearm trait, but only one if it also has the Unwieldy trait.". This doesn't mean that only one fighter can use two weapons, but that any given fighter may use two weapons.
This is one of the grey areas in this debate.
As for your example the close combat rules are only ever talking about one fighter. They could interchange the word “a” with “the” or “the attacking fighter” if they wanted to be specific (but that is already stated in the preceding sentence in that rule) and it would not impact on that sentence. You could still replace the word “a” with the word “one” in that instance and the rule would still work because it is only ever talking about one attacking fighter, though it would be rather clunky.
"A fighter can use up to two weapons with the Melee or Sidearm trait, but only one if it also has the Unwieldy trait." along with "Dual Weapons with the Melee or Sidearm trait (+1)" clearly imply that you can use two melee, two sidearms, or one sidearm and one melee weapon in close combat. There is no language that I can see that implies you may only use a single sidearm in close combat, nor that if you do use two that only one may have attack die assigned to it.
“a fighter can use
up to two weapons with the melee or sidearm traits” does not universally allow you to use two weapons with the sidearm trait. It simply allows you to use up to two if there are no other rules that conflict with it. In fact a rule that does not allow for the use of two sidearm weapons would not contradict this sentence, but simply add another limiting factor to it.
The sentence also allows for a number of other combinations of weapons in a single sentence without having to explicitly list them all, such as no weapons, one melee weapon, two melee weapons, one melee weapon and one sidearm, one sidearm, or two sidearms.
The other sentence “dual weapons with the melee or sidearm trait (+1)” falls in the same bucket. It allows for a lot of options simply, but those options may be restricted by other rules.
In fact there is a specific rule in each rulebook titled “Pistols at Close Quarters” that gives further instructions on how to treat weapons with the Sidearm trait, and that rule is the one that can be interpreted to restrict, not contradict, the general combat rules. It does not contradict the previous rules because if you do restrict fighters to using a single weapon with the Sidearm trait all the previous sentences still work in plain English in all other non-restricted scenarios.
The specific part of that rule that really causes issues is the second sentence that reads “any remaining attacks
must be allocated to a weapon with the Melee trait, if the fighter has no other weapons with the Melee trait, any remaining attacks
must be Unarmed attacks, as described above”.
What people miss (and I did on first reading) is that the first sentence must be implemented fully before reading the rest of the paragraph. “A weapon (in this instance each or any weapon) with the Sidearm trait can only have one Attack dice allocated to it”.
I really think that it's fairly clear that you may use multiple sidearms in CC, and each one used may have a single die assigned to it. There's no particularly logical reason you should gain an extra attack for having a second pistol in your hand... but then being unable to use the pistol that grants the attack to actually perform the attack that is granted.
Again this just comes down to interpretation of the rules. Most rules are abstracts meant to represent real life so trying to implement “real life logic” into them doesn’t always work and shouldn’t be used as the basis for a rules debate. Rather the internal logic of the rulebook needs to be used to try an interptret how they have abstracted “real life logic”.
Also: As an aside: “a piece of fruit with yellow skin may be eaten” can just as well be interpreted as meaning you may eat any number of fruit, as long as they have yellow skin.
I’m afraid you are wrong here. Piece of fruit is singular so you would still be restricted to a single banana regardless of the use of “a” or “any” in that sentence. If I had used the plural, pieces of fruit, instead you would be allowed to eat more than one.
There is also an interesting effect if you change the word “may” to “must” in both instances. Consider the following sentences:
- A piece of fruit may be eaten.
- Any pieces of fruit may be eaten.
- A piece of fruit must be eaten.
- Any pieces of fruit must be eaten.
With the change of requirement for may to must the ability to interpret any in a singular form is removed and it must be interpreted in its plural form.
Anyway English is a strange language with lots of oddities and ambiguities in it.
