N18 Freeze Time v Unremarkable Utterance
takingoff
Sep 10, 2022
4
Hey all,
I'm just theorising for Delaque gang development. I realise powers aren't optimnal to begin with, but they are fun. What do we think of the relative pros & cons of Freeze time against Unremarkable utterance?
A psychoteric wyrm gets around the range issue of the former and is more likely to hit people. But the latter being a simple action and continuous is much more flexible.
Freeze Time:
Pros
- bigger range
Cons
- affects your models too.
- is an outcast power and needs to be leveled into via experience points, and only as a second+ power (unless you became a psyker via non-delaque means).
Unrememberable Utterance:
Pros
- you can start with it at gang creation.
- choirs can increase the range (but not as big as freeze time).
- is a simple action (you can try to cast it twice if necessary).
Cons
- smaller range.
