GorkaMorka - Squats?
Ben_S
Jul 26, 2015
5,003
8,283
208
Southampton, UK
That's why I say count-as Orks. There's no way that Squats are well represented by a T3 and subject to pinning profile. The Orks profile fits fairly well (T4, I2) apart from slightly high M and low Ld.
Ardavion
854
1,352
Why not try taking the squat miners gang from the vault and dividing all the costs by 10 to get them in teef? It's a good approximation of the conversion rate from Necromunda to Gorkamorka.
Aulenback
Yak Comp 3rd Place
Mar 29, 2016
1,590
3,126
178
Halifax, NS, Canada
I'm with Ardavion. Just use the Squat Necromunda gang rules, divide creds by 10 to get teef, and buy them vehicles to suit. The only complication is that all Miners count as Heavies, so there isn't a convenient way to tie number of vehicles to number of heavies, as there is with most gangs [that is "heavies equal spanners"].
I attempted a "use the original with few equipment list omissions" to update the Prospectors' gang list to match the Kharadron models available [instead of the Dwarf Fantasy models with chainmail and crossbows], which might prove useful. You can find it at
https://yaktribe.games/community/vault/brotherhood-mining-gangs.968/
Generally, GorkaMorka rules accommodate Necromunda gangs surprisingly well.
The old Citadel Journal article on importing the one to the other strongly recommends not allowing further access to Necromunda weapons and gear after gang creation, having to make do with ork gear after that. That could work.
Another option would be to mount them all on a mix of bikes and endrinrigger dirigibles, and count them as Muties, with the fancy Mutie tech.
Aulenback
Yak Comp 3rd Place
Mar 29, 2016
1,590
3,126
178
Halifax, NS, Canada
Belated addendum:
Using exclusively endrinriggers and skywardens could suit a direct use of the Mutie Raiders rules [as I did with the knarloc-riding Kroot]. The balloons/flying engines would "counts as" mounts, affecting boarding, making them faster, etc etc. The variety of Kharadron weapons are easily convertible from one model to another, and could easily represent the variety of Mutie weapons.
But I still agree that the simplest by far is to "GorkaMunda" them, by just importing them in. The one starting "territory" that Outlanders get could as easily be somewhere in the desert, given the range of starting territories they get, and if you treat "trading" for them the same as is treated for the Diggas, you could be easily sorted.
Not sure why, I feel Squats could work well with Gorkamorka.
Because they look ace, really, is why.
