Hi Bit of a Newb question here. I know when throwing Grenades you have to make an ammo check each time to see if your ganger has run out. When using a grenade launcher is this the same? Or when using a grenade launcher do I just roll the ammo dice as normal and if no out of ammo result comes up I'm fine?
