Bug GSC some stats are wrong.
St. Jimmy
Oct 24, 2018
5
16
Finland
It's nice to notice these bugs after all these years :oops:
- Cult Alpha has S4 when it should be S3.
- Also Third Arm should give Cult Alpha extra attack like with Acolytes or Neophytes, so the base should be A3 instead. Though the tool likely can't check if Unwieldy is used, so I'm not sure which one is more confusing, the tool giving the attack automatically or it shouldn't give it at all. So maybe Third Arm shouldn't give the attack in the profile for Acolytes and Hybrids....
- Hybrid Acolyte has S3 when it should be S4
Technically the 3rd arm doesn't add an extra attack to the Attack characteristic. It gives you a bonus attack which has to be made with the 3rd arm, the difference being that it can't be doubled by having weapons with the paired trait, for example.
So the Alpha is correct at A2, 3rd arm Acolytes/Neophytes are incorrect at A2 and should instead be A1
Reactions: JayTee and Punktaku
I suspect you're not using the latest GSC rules as found in the BoRuin, as the Alpha definitely does have S4 and the Acolyte is S3.
Can't be changed
It's always that
Doesn't matter what I change this to, there are no different options anywhere.
I mean your reference to what the stats are is old. I seem to recall the S4 Acolytes was in the WD version of GSC, the latest version which is the version in Yak is S3 Acolytes. So there's no bug, the stats in Yak are accurate.
Oh there has been a book where they nerfed the Acolytes and boosted Alpha. Yeah just got the book from one of my friends Yesterday night to check out.
Oh boy the Third Arm rule is especially bad there. Writing is just horrible, because it's different rule on Alpha and Acolytes. What's so hard for them to copy/paste the WD article. Do they really need to nerf GSC :ROFLMAO:
