What do you think about the following as a alternative to the Charge action? If you guys like it, I will add it to the Arbitrator's Handbook. The goal here is to resolve some of the issues with the Charge action as written and, probably, intended in Underhive/Gang War.
Alternate Charge Action
Charge (Double) – Declare an enemy fighter to be the target of this charge. The fighter makes a Standard Move, adding D3’’ to the distance they can move, and must move towards the target in as straight a line as possible. The fighter becomes Engaged (and can ignore the enemy fighter's 1" zone of control) if the total distance moved results in base to base contact with the target enemy fighter. They can also end their move within 1" of other standing or Pinned enemies as long as the targeted enemy fighter is in base contact. If they do this and are Engaged at the end of the action, they can immediately make a free Fight (Basic) action against the targeted enemy fighter. Otherwise they perform the Standard Move + D3" towards the target, stopping short of any enemy fighter's 1" zone of control, and are not considered Engaged at the end of the action.
FAQ
Not part of the rule, but some anticipated clarifications:
FAQ
- In subsequent rounds, the fighter is free to make Fight (Basic) actions against other enemy fighters in base contact instead, but must attack the targeted model when charging.
- If the straightest, most direct path lies through the base or 1" zone of control of another enemy fighter, the move stops short and the charge is failed.
- There is no problem with charging fighters that are not in line of sight.
- You could declare a hopeless charge (say against a model that's two feet away), but you must move directly towards it and cannot enter any enemy's 1" zone of control. It would essentially be a handicapped Double Move.
