Help me make a Genstealer cult warband
Eilif
Jul 19, 2014
369
828
Chicago
chicagoskirmishwargames.com
Just ordered the rulebook and a box of Genestealer cult neophytes. I want to make a waband without buying any more figs except that I'll probably trade a buddy for a purestrain genestealer fig at some point.
Can someone suggest the best way to use the 10 figs in the box, both for starteing and to have a selection of minis as the gang expands. I've got plenty of other figure bits (catachan, cadian and many others) if it would be worthwhile to make additional novices. I've also got a huge selection of addional bits, weapons, etc, so don't be limited by the weapons in the box,
Ideally I'd like to have a selection of between 10 and 17 figs that would povide me with enough variation that I wouldn't have to buy any additional figs for this faction.
1 stubber, 1 nade launcher, you will deffo want both of them.
mining charges are also pretty scary, although not massive modeling restriction there.
a couple with shotguns, a few with autoguns. after that, you can fill it out with what takes your fancy I think from what I've seen of 2 stealer warbands.
I started my GSC gang with;
Leader with pick and bolt pistol,
1 heavy with stubber, photo-visor & clip harness,
1 heavy with flamer,
4 troopers, 1 with chainsword & auto pistol, 1 with autogun, 2 with shotguns.
2 initiates, 1 with shotgun, 1 with autogun.
9 models starting lineup.
I do think I will need to get a second box though shortly, as after 4 games I'm up to 11 models (including a second heavy with stubber).
I think GSC need to have strength in numbers to be competitive, especially against some of the more elite gangs.
Over 4 games 2 initiates were killed and 1 was captured (though I managed to rescue him). I've replaced losses of new recruits, but not given them any weapons as generally they will be used as meat shield for the rest.
Thanks for the replies folks. Is it worth giving some troopers lasguns instead of Autoguns or shotguns? There aren't any in the box, but I've got plenty that I could convert with.
Also, in reconciling fluff, modeling and rules, should the newbies be more or less alien looking?
On the one hand, they could represent an earlier generation and be more alien looking. Perhaps they might also be human initiates into the cult.
On the other, perhaps it's the tougher members of the gang that are the earlier generations with more genestealer'ish features.
I honestly have lost track of generations and which ones are which, so I'll leave it to others for that part.
a mix if fine, the one that stood out to me was a gang where the leader has a lasgun (I'd go hotshot for him too if you can), then the rest have autoguns, makes the leader that little bit more special :p
Mor
ning
I'll definitely echo what spafe said here. Get a grenade launcher with frag and krak grenades. Marine's really don't look so tough when you hit them in the chest with a S6 -3 save grenade. Also the heavy stubber is almost a must. Begin the game in hiding in some high cover and then pin enemy fighters to your hearts content!
I ended up giving my boss a hot-shot lasgun. Its been - ok - . I could have given him a boltgun or an autogun to be honest. He hasnt really done anything of note.
Also - blasting charges! After youve got your gang up to strength buy these for everyone. You wont hit as its a -1 on the roll but who cares? Large blast S4 is fantastic.
Here is my finished Cult of the Four Armed Emperor!
20170504_231155.jpg 20170504_231217.jpg 20170504_231235.jpg 20170504_231305.jpg 20170504_231322.jpg 20170504_231335.jpg 20170504_231346.jpg 20170504_231401.jpg 20170504_231416.jpg 20170504_231431.jpg
Reactions: AndeeT and spafe
Nice looking gang AEB,
A few more questions for you folks.
-Is taking a grenade launcher and stubber worth not having a flamer?
-What do you all think about autogun vs shotgun for GSC?
I'm still trying to decide whether I want my leader to be CC oriented in an un-necromunda world that has lots of tougher opponents. The power pick is so darn cool and fluffy looking but I don't think it's necessarily a wise game-decision.
I would say a flamer is probably the least appealing of the three. Unless you have a decent amount of terrain he is going to have a big of a hard time getting into range to use it. A grenade launcher has the flexibility to fire a template weapon and armour piercing rounds depending on target and has a longer range. Saying that i did use it last weekend up in Warhammer World but sadly there are no "burning" rules in SWA unlike Necromunda so no hilarity when a flaming model runs off a walkway.
I'd go autoguns all the way. Some of mine are armed with shotguns but an autogun has greater range and greater modifiers to hit. Shotguns are good at ignoring cover but considering their short range is 0-4" and anything above that gets a -1 to hit i just cant see the appeal.
Combat isnt as bad as some people think - its just getting into combat that can be tricky!
Very good to know.
I've got some old-school auto pistols that I'll probaly give my novices and there appear to be enough autoguns in the boxed set for the troopers.
As for the leader, I might trim the power bits off the pic and just give it to the leader as a fluffy knife alternative.
Guess I'll go with the grenade launcher instead of the flamer though I don't like the way the included one looks just like the cadian version. Maybe a conversion of one of the other heavy weapons using the GL magazine or I'll head to the bits box and see what I can find. I think there might be some good possibilities in my old Warzone bits.
Remember they are using guard kit... so it makes sense for their stuff to bear a resemblance to the guard stuff.
Having said that, look at the difference between the steel legion, vahallen and plastic cadian nade launchers, and you have a lot of scope for what you want yours to look like! :)
A Power Pick isn't going to lose a game for you. Don't mutilate it. A flamer has some uses. There are times you must hit a target. I would like a second Heavy Stubber, but I only have one. A grenade launcher is the next best thing. You can conveniently buy Krak grenades between games for 100 pts. You will have extra hybrid heads to convert Catachan's or Cadians. I like Catachans, I painted their uniforms blue like my Hybrids. They look like they are striped down to undershirts, or just don't warrent a full mining suit. No matter, it's the same as if they are wearing flak armor, as do Catachan models. WYSIWYG is for fun, not meant to be punitive.
Reactions: Ben_S and spafe
Since I have Genestealer Cult for 40k, Ive been using the models for both Necromunda (as a "mining guild gang", using van saar rules) and for Shadow War Armageddon. My SWA team started out like this:
Leader - Bolt pistol, chainsword
Heavy - Stubber, Autogun
Heavy - Grenade Launcher (frag&krak), Shotgun
Trooper - Autogun
Trooper - Autogun
Trooper - Autogun
New Recruit - Shotgun, w/reload
A reasonable starting team I thought. The heavies have secondary weapons for shooting on the move and for when their primary weapon inevitably runs out of ammo.
I've played a few games, but I'm struggling to see what the Genestealer Cult are actually good at. They're average shooters (with mediocre weapons) amd rubbish in close combat. Even their special operatives (none of which I've used yet) are poor (except probably the purestrain).
Yesterday for example, I played a friend's Ork team and got completely tooled over. My team of useless gits suffered 80% casualties and failed to take even one ork out of action. :/
