@chaosticket , Have you read the confrontation background? That was the precursor to Necromunda, and had these weapon tables in them, played as a very different game, was massively diverse, but still originally based on the 40k universe! There are many takes on how the hive works, and while weapons are more common than I'm sure authorities would like, weapon stashes being stolen from factories etc is punished/tracked down a lot, since its the factory bosses that would get it in the neck.
Reading some of the black library stories gives another inside look into how life is in the underhive, its a big place, some wildwest settings, others as a futuristic dystopia, others with a full on factory where every bean is counted and monitored.... what you make of it is up to you. So asking if someone is aware of the background and the setting seems a little bit pointless (unless they are completely new here asking for stuff its safe to assume most everyone is aware of at least the base setting).
As
@Loriel says, given it would become the new base for all gangs to operate on, it keeps the game fair. My suggestion to make the weapons on the rare item table wasn't intended as a new flat rule, but more as an idea for a campaign setting (ala paradise falls, ash wastes, etc).
I'd be tempted to try and write something like this up as a new table, but beyond stub guns, do people think maybe shotguns or autoguns (I'm thinking a basic weapons and a stub gun being the only always there items), or do you reckon stubs only?
Also only allowing juves to be recruited after gang creation? that way folk cant just load up on weapons only, they will have to buy gangers too if they want them, otherwise have to find heavies and gangers on the chart?
