N18 How to add a Hard-Case Cyber-Mastiff to Enforcers in the Gang Manager?
Jul 10, 2019
5
Hello there!
We have recently started a campaign (my first as Arbitrator) and I am playing as the Palanite Enforcers. Having now accrued 90 Credits over two games, I am looking at/considering adding a hard-case cyber-mastiff - but here is the question:
Where do I find it?
It is not on the equipment list, nor is it in the Add Fighter selections.
Any help is appreciated!
Cheers!
Hey,
Scroll down on your gang into the gang controls bit and select "+hangers on/pets" (I think that's what the bottom says from memory) and just look up the mastiff 😊
Hope that helps bud
Reactions: TommyTheCat
Thank you, drdrybrush! Much appreciated!
Now - in the same vein - where does one find all the various Dramatis Personae - fx Scrutinator-Primus Servalen? Yeah - I am playing against a psychic gang of Delaques, and will soon need "protection"...
Reactions: drdrybrush
Official answer: You find the rules scattered all over the place. Pdf, book, paper with mini or on a dirty old napkin curled under the sofa.
Community answer: Have you checked the yaktribe vault? A community rules compilation? You will find 100% all resources for this game!
Ah, no - sorry! I was imprecise!
I already have the paper rules for Scrutinator-Primus Servalen and KB-88. And yes, TopsyKretts - the Necromunda rules are indeed all over the place, which is HUGELY annoying!
What I meant to ask was, how do I add her and KB-88 in the Gang Manager here on YakTribe?
Cheers!
You have to go in the setting and deactivate the "restrict equipment" option. By doing this you can select everything that can be bought across necromunda, you should find the mastiff in the "status item" section.
Thank you!
That seems to do the trick - otherwise the Hard-case Cyber-Mastiff had a credits cost of zero...in which case I want 20 of the mutts! :-D
