N18 Lasgun vs Autogun (with Math)
HugeSamples
Aug 28, 2022
455
475
73
Often when I'm making a list I have a hard time deciding how to equip gangers. I often come to the debate of Lasgun or Autogun and I never have a good answer.
So here is some math.
BS4+ vs T3 Target
SuccessFail (~)
P(short)2/31/3
P(long)1/21/2
P(S3)1/21/2
P(S4)2/31/3
Lasgun:
P(long) * P(S3) = 1/4 = 25%
P(short) * P(S3) = 1/3 = 33.3%
Hotshot-Lasgun:
P(long) * P(S4) = 1/3 = 33.3%
P(short) * P(S4) = 4/9 = 44.4%
Autogun (at least one wound):
One Shot:
Two Shots:
P(long) * [1-P(~S3)^2] = 3/8 = 37.5%
P(short) * [1-P(~S3)^2] = 1/2 = 50.0%
Three Shots:
P(long) * [1-P(~S3)^3] = 7/16 = 43.8%
P(short) * [1-P(~S3)^3] = 7/12 = 58.3%
Average (taken from shots available on the firepower dice--1, 1, 1, 2, 2, 3):
Long = 31/96 = 32.3%
Short = 31/72 = 43.1%
Summary (chance to cause at least one wound vs T3):
LongShort
Lasgun25%33%
Hotshot Lasgun33.3%44.4%
Autogun32.3%43.1%
BS4+ vs T4 or T5 Target
Same method as above using the following probabilities:
SuccessFail (~)
P(short)2/31/3
P(long)1/21/2
P(S3)1/32/3
P(S4)1/21/2
Summary (chance to cause at least one wound vs T4 or T5):
LongShort
Lasgun16.7%22.2%
Hotshot Lasgun25.0%33.3%
Autogun23.5%31.3%
Good maths crunch, holds with my general experience that the autogun is better than the base lasgun at killing.
What this doesn't take into account is that the lasguns short range is 10" longer than an autoguns, so the lasgun is better at hitting people from longer range.
So if what you're looking for is a back liner to pin people, get a lasgun, if you want someone to move up the board and kill something, get an autogun.
There's also the issue of Ammo Checks/Reloading. A basic lasgun has a high likelihood of not failing an ammo check roll (2+, so 1/6 chance of failure) and is also Plentiful, so if there is a failed ammo check then there is no possibility of a wasted action the next turn to reload. An autogun has a 50% chance of failing an ammo check and then another 50% chance of failing the next turn trying to reload.
Lasguns are highly reliable, more accurate at longer ranges, and the exact same price as an autogun. The autogun has the potential get extra hits via Rapid Fire, but is also more likely to go out of ammo. Neither is much of a killing weapon, lacking both strength and armor penetration/high damage to consistently put wounds onto enemies, so they are both pinning weapons. Really, it comes down to availability (not all gangs have access to all basic weapons without visiting the TP), cost (some gangs get a discount one lasguns), and personal preference (some like the look of one over the other), but overall the lasgun is probably the best low-credit weapon to outfit a standard ganger.
I'd probably compare the Autogun long range probabilities to the Lasgun short range probabilities in that case. An Autogun is going to be at long range most of the time, while a Lasgun is going to be at short range most of the time.
where does a worn out autogun on a stick fit into this?
Same place as reclaimed ones… you’re gonna struggle to reload.
But at least on a stick you can poke your opponent from a distance.
I appreciate the calculations but let’s not forget, the designers most likely did none of this and went on “feels right”.
Which it’s why it’s dangerous to go down this route, we all know some weapons will outshine all others, especially in the hands of certain fighters.
Problem is, at that point you just end up playing Horus Heresy, with everyone armoured and tooled up the same - which is not supposed to be the philosophy of Necromunda.
If this game was mathematically balanced then it would probably be made by another company.
You also have to take into account who is buying what. A lasgun for an escher is only 5 cred. That has a big impact in the begining of a campaign.
Im inclined to think that they did do this math to some degree but dropped the ball when it came to pricing things.
To me, this autogun vs lasgun situation represents an aspect of a real strategic decision.
Namely; am I going to invest in skills, hangers-on, equipment etc so I can buy boltguns and autoguns for all my guys?
or
Am I going to prioritise reliability and get everyone lasguns and not bother with it?
Thats where the crunch really is imo
i support heart of storm's post,
there are also a few similar articles on goonhammer/mathhammer about most weapons.
perhaps a small addendum would be how multiple autoguns with rad-rounds could affect a gangs damage output.
or how lasgun pinning would work in combination with some highly mobile template (flamer/shotgun) users.
There's also the sheer utility of having a greater chance to pin - and pinning in itself can be a useful tool to get the enemy to waste actions to stand up. Not to mention the potential threat of gravity-assisted sudden unplanned lithobraking.
Those pesky details are nigh impossible to calculate mathematically!
