N18 Lasting injury cost adjustment
Borvin
Oct 1, 2016
108
249
48
Jena
Hello everyone,
It seems odd to me that it hasn't discussed before, but i couldn't find anything so I'll have a go at it. If it was discussed allready my apologies.
My H2H Redemption Leader really had some bad luck this campaign giving him 2 hand injuries and 1 enfeebled result. I gave him Aortic Superchargers and an Advancement to negate the negativ effects. However i came to notice that i now have significantly more expensive Leader that isn't really better that he was at the start. This is because lasting injuries do not lower the credit value of a ganger but Bionics and advancements increase it.
+1WS = 20cr, Bionic Arm 45cr
+1T = 30cr, Aortic supercharger 65cr
From my Perspective it would make sense that injury lowers a fighters value as much as an advancement adds in cr. value. So Hand or Eye Injury -20cr, Enfeebled -30cr. If you mend that with advancement it evens out, if you use Bionics you'll still be more expensive but not that much. Eg. my Boss would only be 345cr instead of 415cr.
I think this would help balance out gangs more evenly in a campaign and if i am arbitrating the next one I'll rule it as such.
What do you think about that? has anyone maybe even tried this in their campaigns?
Looking forward to your feedback!
Yup, wear and tear increases rating. This is a common design choice for GW campaign skirmish games, ref Blood Bowl, Gorka Morka, old Necromunda, Mordheim etc.
The problem by reducing cost when injured is this increases the growth over time and reduces tear. Your gang is supposed evolve with a mix of growth and also becoming weaker.
In Blood Bowl, I had an epic Wardancer with Agility 6 and Sidestep. Over time, he suffered multiple niggling injuries and -1 AV to the point where he would become knocked down from a stiff breeze :LOL: My choice was hard, let him go to improve rating, or keep him for his qualities? I think I ended up retiring him after a while.
In your case it's more difficult since it's the leader and you can't voluntarily retire that fighter. So your best choice is to try to suffer enough lasting injury rolls to die. Of course you're free to house rule any way you wish. Just be aware that this leads to more growth.
My main issue is not the lack of reduced rating for injuries, but the extremely high rating of bionics! And also the balance, I think bionics to repair strength is one of the most expensive? Ridiculous.
Yeah bionics don't really improve you they just make up for an injury. I like their cost in credits and how rare they are.
I've dabbled with bionics (not the van saar technic what nots) don't increase the value of the fighter equipping them. This saves you having to think about possible reductions. I figure the fighter isn't worth any more and you lose out on those credits to spend on the gang. I'd you use an advancement, yep increase the cost of the fighter you took time instead of resources to fix it and you could still buy a bionic to fix the original injury...
@TopsyKretts
I figured it could be by choice since it is so obvious but if true i really do not understand the reasoning behind it. Since the gang value is also used to approximate a gangs "punching power" and determine measurements to even out chances, like additional tactic cards, Hanger ons etc for certain credit differences.
So the mechanic seems to be a self reinforcing disadvantage for Gangs that don't fare well bc it inflates their rating while the capabilities go down wich then makes it so that they do not get the amount of compensatory measures they might need which makes injury more likely.
To be clear I do not see myself in that position currently, as I am 2/4 in Gang-Rating, 1/4 in kills and 2/4 in territories. But I am looking to be arbitrator in the next campaign an I want to make it more fair as currently our Nr. 3 & 4 players are increasingly left behind.
@Vonvilkee
I think that is a worthwhile approach too, for the reasons you gave.
The problem really is, that the credit cost in the market (which for bionics I think is good and fits the fluff) also constitutes the "power rating". From a simplification point of view this makes sense but with bionics weakpoints become obvious.
So bottom Line I think I will house-rule, that lasting injuries lower the gangers cost equal to the equivalent advancement and Bionics, while costing the full price in the Market, they only increase the gangers cost the same amount that it has been decreased before.
I'll let you know if that will be accepted and if it works.
I'd prefer the injury to be factored in just because I think the slow rate of advancement makes gangers really boring. They'll tend to get worse faster than they get better, and so something to compensate for that feel-bad realisation would be nice. It's not as good as just... getting advances and becoming interesting, but it's something. Plus the idea of a ganger with a selection of inconsequential injuries making them a lean mean rating-slimming machine is kind of cute.
@TopsyKretts
Yeah you make some great points and of course that adds to cons of my explanation. In worst case yes it can worsen the situation further in a downwards spiral. In best case it means you still grow but sometimes need to make difficult choices to let some highly skilled fighter go because they're also too weak. It's not perfect and I get your point on rating, so to my defence I can only say "it's always been like this" haha :LOL:
I get the points made but sometimes the lasting injury has no effect on some fighters apart from they miss a game.
Do corpse grinders really suffer from penalties to BS when they never shoot anything, or any melee only fighters for that matter.
Also who cares if your fighters brain is scrambled and you lose intelligence or willpower?
Yes that is probably the main argument. Without perfect or conservative implementation, it motivates or rewards injuries.
That is indeed a good point.
I don't have the cr. value at hand for the increase in willpower or intelligence, because I currently have to do this annoying thing between Necromunda games that you need to do to be able to afford minis (work). However I suspect that it is rather low (5/10cr?). So even if someone gets hit in their head twice, which would be an rather unusual exception, it wouldn't make them too much of a lean and mean beast.
With BS in a H2H Gang i agree, even more so then WS in a shooty gang (bc you still might find yourself being charged even though if you don't want to figh H2H). I'm not sure how to handle that but its good to have an eye on that and adjust if necessary.
How in x many years of playing this game have I never considered this or heard anyone mention this before?
And to make it worse, factor in chaos injuries and how to rate those accurately?
Ah but those only appear in Chaos Cults or special campaign types, right? Heard about them but can't remember to ever have them actually appear somewhere in my games 🤔
And yes mostly it is negligible, and probably mostly me charging my Redemptionists head on into everything in bloodlust, i mean, righteous zeal for the emperor...
@Punktaku Idk, it came right at me when I used an bionic on an injury after using an advancement to even out another and I was just like "Damn my boss sure looks like a beast cred wise but hes basically the same dude i started with...
Maybe its because im just a free thinker? 🥴😂 *tips Feodora*
In theory you and your opponents all get the same chances of lasting injury so in theory it balances out.
However real necromunda life happens. I have a mate who lost his first four games and dozens of lasting injuries in his first introduction to necromunda and wargames in general. However, he rolled the max income possible for all those games and got juves and gangers from his settlement rolls every battle.
Theory and probability sucks.
Bionics do have a protective effect, not 100 % but something, against further lasting injuries to that area so mitigation this way can pay off.
The events in question are affected heavily by prior events, so the law of large numbers doesn't inevitably lead it to even out. If you happen to take it in the shorts in your first couple of games, you can end up with multiple fighters perpetually in recovery as you never get to fight at full strength, and probably have less money due to replacing fighters and not winning territories or scenario objectives. The snowball effect is hard in this game, so even a well-balanced start will tend to turn uneven and stay that way (barring exceptional luck like your friend had with income).
This is what Necromunda is about. It´s one of those few games in which your progress isn´t guaranteed, in fact you can go backwards. The lasting injuries not counting to rating is one of those effects, and in my opinion it fits perfectly to the theme.
About bionics, these upgrades are there to "save" a very important fighter of your gang, with a lot of xp/advances on it. Usually it is cheaper to replace an average ganger than invest on bionics, and once more, that´s into Necromunda spirit.
All in all, having lasting injuries is not such a big deal most of the times. You have to live with that, and that adds flavour to a gang: some of your gangers will survive and improve, others will get worse and finally dissmissed from your gang, and some others will fight with some drawbacks. Bionics cost and inflated rating for your more seasoned fighters somehow make the evolution of those harder in the long term, and considering how many times snowballing has been disscussed as one of the main issues from current Necromunda, I can´t see it as a bad thing on its own.
Reactions: JayTee
My group finds the injuries add a lot of flavour. Once a ganger has too many we all find ourselves hoping that they (or champ or leader) die. It has made some random games were we try to kill them and they refuse to die. We don't even try to repair the damage with bionics.
I think the rules are fine, and you always have the option to retire any member of the gang BRB pg#93
Reactions: Covenant
Any reason you can't just shove the hapless damaged ganger into a servitor chassis or harvest thier skull and brain for computing? It is a grim dark future after all...
Reactions: Covenant
