Ld 9 and Impressive Scars
Hi all, I'm new to the forum, but my friends and I have been making use of the excellent campaign management here on yakromunda for a little while now.
Anyway, something came up a few games ago that I wanted to get some opinions on.
I have a ganger who already has Ld 9, which is the maximum allowed for any gang fighter, according to the advancements rules. But he's subsequently acquired some Impressive Scars (being shot with a plasma pistol will do that to you...). This takes his Ld to 10, which the yakromunda gang roster has happily accepted.
So should his Ld now be 10? Since he didn't get the last point from an advancement. Or should it actually still be 9? Meaning his badass scars have no effect.
Thanks in advance!
I'd say keep it. Skills and scars are above and beyond normal progression, these are the incidentals that make gangers truly unique. It's like his path has lead him to become the leader of the gang, and he's got leadership qualities above that of normal men. You'll have to do a leadership challenge though!
I like that he has Ld10, even though I can't really make use of it unless my leader goes out.
We don't enforce leadership challenges in our campaign (as it's not in the main rulebook), although players are free to do it if they want to.
Being as my gang leader is 'Mad Dog' Tannen (I'm hoping you'll know who that is!), I like to think that my Ld10 ganger is the brains behind the operation, and the gang 'allows' Tannen to remain leader because of his reputation. Of course, Tannen thinks he's leader because no one dares say otherwise. ;)
Or some such nonsense!
We enforce LD challenges as we feel its a mechanic to prevent gangs from becoming too powerful, but also it makes sense as we dont understand why you would suddenly go from using low LD to high LD if your leader goes down or OOA. we also play impressive scar as an exception of advancements, so normally you can advance to 9 but IS will take you to 10
9 is the max unless you house rules says otherwise, but it would be milking it at both ends since i'm sure people who had impressive scars first then rolled a leadership advance would be claming they are maxed out so get an initiative advance instead as per written rules. ;) The scars are sort of an instant advancement cause of the ordeal, gaining self-respect and extra bravery... but Ld 9 is as brave as most people get unless they are completely blinded by faith like the redemptionist.
Impressive scars dont stack on each other, they are a lucky result instead of being crippled or killed. If a model gets Impressive Scars at Ld9 then they just managed a Full Recovery with an interesting conversation piece. =D
Not that i've done it but rather than Ld 10 i would suggest a surplus impressive scar can cancel out a single future Shellshocked injury result. 'that was real scary now i'm all jumpy, oh wait, its exactly like the time i got this scar, sweet i'm good'
Cheaper than a headshrink, but to be completly honest you would have to take dud LD upgrades until reaching yu maximum rather than claiming initiative advances :p
I always say special rules override normal. And using bulging biceps as a case in point, the stat line max can be overridden by a special rule. And if you get 2 impressive scars then add 2 to Ld, though a roll of 12 for a Ld test is an auto fail.
Leadership challenges are great fun, if your leader wins you can do whatever you want with the upstart challenger, and he'll never challenge again. So you might injure him and give him impressive scars again lol!
I guess this is another case of NCe creating precedents for more changes. In the case of bulging biceps it specifically mentions it though unlike impressive scars... which still says the increase is only once ;D
In Gorkamorka they put into the rules that a Impressive Scares result can put you up to Ld10..
So if you are Lucky enough to get it when you are at Ld9 then go with it =D
