N18 Looking for help with Ash Nomads in Underhive
Xen ark
Feb 9, 2021
11
Hello there,
I'm new to Necromunda with the Ash Nomads and I'm a bit lost when it comes to making an underhive list.
Do you have any examples of lists or a link where I can look at some?
I'd like a list that's a bit of a hybrid between shooting and close combat. I don't know if that's possible.
A list that includes a few insects would be really cool.
Thanks in advance!
Jonathan
This list is more for close-up shooting, but the leader is build to melee support
later the leader could take more combat skills and ash wing helamites or a venom caster
  1. the leaders inspiration will boost the cool of the duneskuttler (when I buy it) to keep it mobile (nerves of steel needs a good cool).
  2. bring it down will help the heavy blaster & more distant ranged damage dealers to hit
  3. blast carabines have "+2" to hit at short range so the idea here is to get close and unleash hell
originally I took a sha'adar hunter with bugs but since the special infiltration rules doesn't work in the underhive I left him out.
Goonhammer also released a nomad guide 2? weeks ago:
Btw, considering your name, do you happen to be Belgian?
I'm in the early stages of getting a few necromunda-players together
Reactions: Xen ark
Cette liste est davantage destinée au tir rapproché, mais le leader est conçu pour le soutien au corps à corps.
plus tard, le chef pourrait acquérir davantage de compétences de combat et des hélimites à ailes de cendre ou un lanceur de venin.
  1. l'inspiration des leaders va booster le cool du duneskuttler (quand je l'achèterai) pour le garder mobile (des nerfs d'acier ont besoin d'un bon cool).
  2. le faire tomber aidera le blaster lourd et les donneurs de dégâts à distance à toucher
  3. les carabines à explosion ont « +2 » pour toucher à courte portée, donc l'idée ici est de se rapprocher et de déchaîner l'enfer
à l'origine, j'avais pris un chasseur de sha'adar avec des insectes, mais comme les règles d'infiltration spéciales ne fonctionnent pas dans le sous-sol, je l'ai laissé de côté.
Goonhammer a également publié un guide nomade il y a 2 semaines :
Au fait, vu ton nom, tu ne serais pas belge par hasard ?
Je suis dans les premiers stades de la création de quelques joueurs de Necromunda
Ohhh, merci pour votre réponse rapide !!!
Eh bien, je suis français, mais j'ai étudié en Belgique pendant sept ans (j'adore la Belgique), et maintenant je vis près de Disneyland Paris.
Je vais étudier ta liste, mais j'ai un peu de mal parce que, comme un vrai Français... je ne parle pas anglais (j'apprends, j'apprends) :D
Avez-vous Discord ?
J'adore la figurine Duneskutter. Elle n'est pas sur ta liste, mais tu la mentionnes au point 2. L'achèteras-tu plus tard dans la campagne ?
(Je suis d'origine un Flamand Francophone)
Peut-être l'app Deepl pourrais t'aider pour la traduction de Goonhammer? c'est un article hypercomplet
On n'a pas de discord ici, seulement les messages privé (la petite envelope en haut à droite),
mais il y a aussi le discord de Mundamanager ou le Reddit necromunda pour les question tactiques.
Exactement... si je l'achèterai trop tôt je devrais prendre moins de figurines/gangers et chaque perte risques de faire fuir mon gang.
Tu pourrais laisser tomber le blaster lourd pour un duneskuttler, mais dans ce cas tu risquerais d'avoir qu'un 1-2 champions mal-armé.
Reactions: Xen ark
Your list is illegal, Sha'dar Hunters can't take carbines.
I made a list of my own, here:
Note that the armor can be dropped to afford a Juve with a Reclaimed Autogun, I'm just so pessimistic about this being useful I spent the credits on armor for the gang hierarchy instead.
I looked into it:
I tried correcting the ganger type on MM but there is a bug not correcting the the ganger type completely
I'll report it (and I'll get around it by deleting/recreating that ganger)
