Making Gorkamorka slim bases with resin
Discussion in 'GorkaMorka' started by Thrakka, Mar 11, 2017.
  1. Thrakka
    Thrakka Juve
    Map
    Well a month back I got the gorkamorka bug and have been buying all kinds of old stuff off of eBay the problem I've had is lack of bases for the stuff I've been getting.
    So as usual I went on ebay and found limited amount and the ones I found were expensive.
    So as the saying goes necessity breeds invention.
    It's easy to do and quick as the resin sets pretty fast I found some pound shop two part resin for, you guessed it £1...before that all I did was fill a lid with standard silicon about £1.50 a tube from a builders merchant. I then used a coffee jar lid and filled it with silicon smoothed it flat and poked the original gw base into the silicon and waited for the silicon to set. Be careful when removing the original base once set as the silicon may tear so take your time once out you have a mould that you can use as often as you need.
  2. Oddsox
    Oddsox Ganger
    Map
    Fanastic idea mate! I would love a step by step guide with a few pictures?
  3. Thrakka
    Thrakka Juve
    Map
    Yesh I'll sort that soon
  4. Yeoman
    Yeoman Ganger
    Yak Supporter
    Map
    Are they heavy enough to hold the miniatures standing?
  5. Thrakka
    Thrakka Juve
    Map
    They are pretty much the same weight so they will hold the miniture
    Yeoman likes this.
  6. Ezaviel
    Ezaviel Juve
    Map
    That's an awesome idea. It drives me nuts that I have more Gorkamorka orks than I do bases (so many old metal models going around ebay with the wrong bases :( )
Share This Page
