I'm going to attempt texturing some bases with green stuff. What do you guys do about the slots/tabs when doing this? Do you just cut the tabs off completely and not use a slotta base? Just glue the mini onto the green stuff? Pin it? I'd like to ideally keep the tab intact and use a slotta base so it's more secure, but I'm not sure if I can do that AND still texture the green stuff on the base nicely (I've got one of those textured rollers).
Also, do you guys wash your terrain? If so, what with? I'd like a Nuln Oil like effect, but there's no way I'm paying for that amount of it!
And finally, what are you guys using for water/liquid effects on terrain? I'm planning on making a modular canal thingy full of toxic green radioactive sludge. Epoxy resin seems to be expensive unless it's Epoxy Acrylate (is that the same stuff? Is it usable?), and I'm not 100% sold on just using layers of gloss varnish.
Thanks
Thanks
