N18 Missing options when making a cawdor HoF gang
abefactory
Jul 18, 2020
6
When im making a Cawdor HoF gang i am missing some options on the priest such as matercrafted weapons and the cherubs.
Is there a reason as to why i cant choose them in the gang creator?
Hi, I had this problem when I first made a gang as well. The Cherub isn't in the Leader's option, for some reason, but you can buy one for a champion, tansfer it to the gang stash and then over to the leader. As for the Master-crafted weapon, you will need to use the Custom gear option in the Underhive Tools. Create a Custom Equipment item called Master-Crafted "Whatever" with the appropriate cost, rarity etc. and then, in the Custom Weapon Stats section, you can create the weapon by copying the existing weapon stats from the rulebook and adding the "Master-Crafted" trait. It's a bit of a round-about way of doing it but I understand it's the only way at the moment.
Hope that helped.
Yes, the cherub thing can be corrected when there is time (@Malo ). But this may take a while as there is lots of other things that takes up our blessed techpriest and overlords time.
The mastercrafted is not really fixable. This is because while there are some mastercrafted options in house of books, the trading post allows every weapon to be mastercrafted. It isnt fesible and would take up too much space in the drop downs on the tools as to make them unwieldy to create master crafted... everything. Therefore as above, you can use the make your own kit for the ones you need.
Reactions: Oojamaflip13
