Necromunda N.S.Grizzled Crew (Orlock gang start to finish)
Resmire
Yak Comp 3rd Place
Aug 25, 2017
385
1,206
203
Manchester, UK
This a thread to show start to finish the building, converting and painting of my Orlock gang. The crew of the N.S.Grizzled, hunters of the many dark monstrosities of the Necromunda Sump/Sludge sea.
Captained by Captain Baha, he searches for the great albino sump spider for revenge and glory. The Grizzled is intended to be a sump steamer, probably a cross between an ironclad and a whaling boat.
Will be posting whatever I build, whenever I can. I will give brief run downs of how and why i build, convert and paint the crew the way I do.
Argh ... beaten to it. My Orlocks just arrived and I’m planning on putting Escher heads on them too.
Either the Fusion Felines or the Sump Sea Sirens.
It wasn’t anything to do with the fact the Orlock heavy has a Harpoon Gun was it?
Reactions: Resmire
I actually bought these from warhammer world the day after yakmeat ended, literal pure coincidence haha
https://yaktribe.games/necromunda/gang/n.s_grizzled.33400/ if anyones interested to see the loadout, (harpoon launcher counts as M.Launcher)
Reactions: MancInventor
Near complete build for Rachel
I shan’t be sculpting anything onto them except the head swaps. I want them to be either Burch female Orlocks, or Pretty Boy Orlocks.
Might see if other companies do female heads.
Reactions: Resmire
So a very brief rundown of how i've built Rachel up to this point, used the basic base that comes with N17 kits, mainly because im going for a very industrialised nautical theme, lots of metal, lots of mesh, lots of hanging wires etc.
The mini herself is quite simple, just a basic body from the N17 Orlock kit, with stub gun and knife, nothing too interesting there, used standard gw clippers, standard citadel plastic glue for her main assembly. Pistol was drilled out with army painter hand drill (I like the out of the box options it comes with) and i drilled a hole through the neck area of the torso straight down. I've than 'appropriated' one of @Edelweiss N17 Escher heads, this ended up being a bit of a big due to the surprising head size and shape difference. It required me to build the head as standard with choice of hair, and then when set drill straight up from the base of the skill where the neck will connect. I then pinned it using paper clips and loctite control super glue. Once in place i wrapped a thin strip of green stuff directly below the head to hide the pin and also to act as a neck. I waited till it dried and then clipped the pin the correct size with test fits, I am still currently in the process of using liquid green stuff to get the smooth shape and texture i want.
The little 'friend' she has is eventually going to be a raft sump spider, a spider that runs on water. I've not decided if she's tamed it (doubtful, due to the high cost of their eyes and the captains utter hatred of the things) or if she's being 'boarded' by it. It was made simply with two blobs of green stuff on a paper clip, like a snowman, and then using cut offs of paper clip I have lying around burrowed into it and then super glued, i used a basic google search for raft spiders as an idea of the positioning for the legs. Its not perfect but i think it's at least interesting.
I'm going to paint her up as concept of paint scheme before I progress any further into the building of my gang.
TTFN
All i'm going to say in regards to the head swaps is (as i've written above just now) they're a bit of a pain to look right, since the escher heads have literally no neck on them. They don't look bad with a little work but maybe finding something more similar may best the easiest option. Can't wait to see what you build!
Reactions: Azzabat
Interesting idea...
I think you need to re-sculpt the lapels of their jackets to be a bit more open if you are going to add that much um... detail. ;)
Reactions: Resmire
1st prime of black with a new spray i've not used before. I'm not entirely sure on it yet. It took a long time to dry and even after a full 10 minute shake the pigment seemed to come out a little heavy. It's purely water based so i'm assuming thats why the dry time was what it was. I panicked when sprayed it initially since it seemed to flood the details, but as it dried it seems that the pigment settled onto the mini quite well. My only real issue with the finished 1st prime is that the base got a little flooded.
pricey! how’s the odor? if they don’t stink like normal spray cans i may have to ignore the price. They actually have one called “Ultramarine Blue” that looks like Ultramarines blue.
Reactions: Resmire
The odour is minimal and doesn't hang around, its unpleasant but nothing compared to the normal rattle can chemical/glue odour. I'd say its good to an extent but its definitely something you'll have to have a play around with. Cassart is where i got it from as well and although not cheap for the size, because its not filled with propellant it has a surprising amount in the can.
I'll give further reviews as i use them more. They also have a reasonable basic range of colours to boot.
i checked out the Montana site, and i was surprised to see they’re from Spain and available on my side of the pond (New England, not Jolly Olde England)
although there is a Bristol here as well
Reactions: Resmire and Azzabat
Do they have pirates in your Bristol @Punktaku ?
I met a group of “proper” pirates while at the pub last night. They were at the Llandogger Trow pub opposite us, famous as the place where the author Daniel DeFoe met the shipwrecked sailor Alexander Selkirk upon whom the book Robinson Crusoe is based. So I may soon be joining the Brotherhood in Black.
Reactions: Resmire
