N18 Nerves of steel and spells
Apr 10, 2019
25
10
Monterey, CA, USA
A player was playing a delaque caster. He was casting some type of spell against a model that had nerves of steel he stated that since it was a psychic attack and not a range attack that nerves of steel does not apply. Is this correct? I am assuming it is not correct. But this game is complicated.
Spatial Psychosis is not an attack as it does not have a weapon profile. Therefore, Nerves of Steel does not apply.
Fun bonus fact, Coupe de grace (edited for spelling) is also not an attack.
So it's unique to spatial psychosis? Does the nerves of steel require a weapon profile to work? It just says range attack for it to trigger. Other psychic range attacks would trigger nerves of steel or not?
It's not unique to Spatial Psychosis, there are other psychic powers that pin.
Some powers grant a weapon profile and are considered attacks, such as some of the powers from Pyromancy.
None of the Delaque Psychoteric Whispers grant a weapon profile and none of them are considered attacks, ranged or otherwise.
An attack is something that has a weapon profile. If you are affected by something that doesn't have a weapon profile and pins you, then you are out of luck with Nerves of Steel.
Interesting, several powers work by targeting an enemy within a range and LoS, then make a hit roll using BS. Pretty close to a ranged attack, but still not quite?
Those usually come with a weapon profile attached to them, and thus are ranged attacks.
I don't have the Book of the Outcast handy, do you have an example of power that meets that criteria that doesn't have a weapon profile attached to it?
By weapon profile I mean something like:
Short RangeLong RangeShort modifierLong modifierStrengthArmor PenetrationDamageTraits
So having a weapon profile determines if it is a range attack? Is there somewhere in the rules that state this? I was under the impression that nerves of steel straight just works unless it explicitly is stated that it doesn't such as with siesmic trait.
Unfortunately an "attack" isn't explicitly defined anywhere. This was the best, most consistent definition me and my group could come up with.
Another person brought up a similar question with booby traps here:
At the end of the day it's really up to your arbiter.
I was under the impression that nerves of steel straight just works unless it explicitly is stated that it doesn't such as with seismic trait.
It specifically says "ranged attacks", if it wanted to work on everything they would have said "make a cool check to not be pinned" and omitted that detail. (Note the ranged attack clause is why Spring Up is generally the better anti-pinned skill).
Personally I'd stick with the weapon profile definition for what is considered an attack (attacks are made with weapons).
It's simple, clear, and doesn't have edge cases.
That said feel free to lawyers up a more specific definition for your group. As long as everyone agrees then you don't have a problem.
In my opinion, the spirit of Nerves of Steel is that they are being cool under pressure (getting physically hit with a bullet, shrapnel, explosions, etc). Not that they have mental willpower to resist psychically induced vertigo.
The examples referred to are from the wyrd powers in outcast which specifically had no weapon profiles.
Hailstorm (Basic): Immediately make a hit roll against every fighter, friend or foe, that is within 12" of this fighter, using this fighter’s BS. Each hit scored is resolved at Strength 1, Damage 1 and AP -.
Crush (Basic): Target a single enemy fighter or obstacle that is both within 12" and line of sight of this fighter and make a hit roll, using this fighter’s BS. If a hit is scored, an obstacle is destroyed and removed from the battlefield, while an enemy fighter must make a save roll. If this save roll is successful, roll an Injury dice and immediately apply the result against the fighter.
They are written in such a way as if supporting your definition of ranged attack requiring a weapon profile :D
Fun bonus fact, Coupe de gras is also not an attack.
Coup de grâce not coup de gras.😂 The first one mean mercy killing the last one mean striking with fat. It's pronounced like grass.
Also quick question if the psychic power has "a weapon profile" could it be use in CC like crush because it's specifically say within 12. This for me include CC.
That's a good point. I believe it can, because it isn't strictly a ranged attack? But using BS is at least a hint at it not being intended? Same goes for Pinned.
Edit: Arguably, Crush isn't a ranged attack, so perhaps yes. But for wyrd powers with an actual (ranged attack) weapon profile, it should perhaps not be used in CC?
So, not 100% sure on original answer, but…
Nerves of Steel: “When the fighter is hit by a Ranged Attack…”
Shooting: “There are several ways in which a model may make a Ranged Attack against an enemy model, most frequently by performing an action that allows it to do so, but certain skills and gang tactics will also allow various models to make a ranged attack outside of the game’s normal sequence.
Whenever a model makes a ranged attack against one or more enemy models, this sequence is followed:
  1. Assess Target Priority
  2. Declare the Shot: “choose a ranged weapon the model is armed with”
  3. Measure Range
  4. Make the Hit Roll: “a hit roll is a ballistic skill test”
  5. Resolve Hits
Spatial Psychosis: “Choose a single enemy fighter within 12" of the Psyker, that is Standing and is not Engaged. That fighter immediately becomes Pinned.”
So, from that, I’d note that Spatial Psychosis does not require steps 1, 2 (in the sense the fighter is not ‘armed’ with a weapon called ‘spatial psychosis’) and 4, which are the steps which constitute a Ranged Attack.
There are of course ranged attacks which also miss a step (e.g. Template weapons) but the rules for template weapons explicitly state which steps they miss out.
Are there examples of explicitly named ’Ranged Attacks’ which ignore the usual step-by-step process for a ranged attack?
If not, I’d say Spatial Psychosis is not a Ranged Attack, and so does not trigger Nerves of Steel.
If so, then yes rules need clarifying.
My gut is (and I don’t recall if ever come up against this) it is not a ranged attack, and does not trigger Nerves of Steel.
And from a narrative point of view, being Pinned is supposed to represent being knocked of your feet by an unexpected shot, or ducking out the way of a near shot. Nerves of Steel represents being a hard case who takes the shot without being knocked over or being unphased by the fire. Spatial Psychosis however represents a psychic attack confusing your senses and making you lose your sense of balance. Being so hard, or so stupid, that you don’t duck doesn’t affect that.
This technicality has some implications. Against Nerves of Steel (and other special rules that protect against ranged attacks), having a wyrd power "attack at range" like Crush seems better in most cases than having an wyrd power with weapon profile? So a wyrd power mimicking a ranged attack is better than a wyrd power with an actual ranged attack (weapon profile). Looks like different wording for wyrd powers varies over time, but these variations matter. Without ranged attack, do they even ignore save? Save triggers on "hit"? Perhaps they're all worded in such a way that wyrd powers that inflict damage are described as "hits", while wyrd powers that do other negative effects don't use the word "hit"?
Reactions: Beebopalulla
I though saves triggered on wounds?
Or were you specifically talking about Crush?
TBH, it's not even clear if Crush pins 😅. It probably does? It uses BS to hit and roughly goes through the "Shooting" sequence and sort of has a weapon profile:
0-12" range, no mods, no str, no wounds, no ap, special rule in the traits column.
Thematically it's a "physical attack", crushing someone with your mind.
Quite the mess GW has made for themselves with the rules.
Haha wow, what if it doesn't even pins? But when I read the rules regarding armour save, it is triggered by "hit" yes. So a lot of effects can give "hit", thus enabling save. But if an effect doesn't give a hit, then it also ignores saves.
An armour save is triggered by any ‘Hit’ which results in a wound or injury roll.
”If a hit results in a successful Wound roll, or leads to an Injury roll being made against the fighter for any reason, the fighter may be able to make a Save roll.”
Relevant Psychic Powers as below… the use of a description of a ‘hit’ aligns (in my view) with the description of the power as to whether it results in a ‘physical’ assault that armour might offer protection from:
“Hit”
  • Pyromancy - Molten Bolt (“If a hit is scored, it is resolved at Strength 8, Damage 3, AP -3”)
  • Telekinesis - Assail (“make a hit roll, using this fighter's BS. If a hit is scored, move the target D3" in any direction … suffer a S3, AP -, D1 hit”)
  • Telekinesis - Crush (“If a hit is scored, an obstacle is destroyed and removed from the battlefield, while an enemy fighter must make a save roll.”)
  • Telekinesis - Hail Storm (“Each hit scored is resolved at Strength 1, Damage 1 and AP -“)
  • Psychoteric Whispers - Suicidal Embrace (“This attack automatically hits, but must roll to wound and inflict Damage as normal.”)
  • Spyker - Force Blast (“If this movement is interrupted by a wall, or other impassable terrain, the fighter is immediately Pinned and takes a hit with a Strength equal to the number of inches rolled for the push distance.”)
No “Hit”
  • Biomancy - Cause Pain (“That fighter must roll an Injury dice and immediately apply the effects.”)
  • Psychoteric Whispers - Spatial Psychosis (“Choose a single enemy fighter within 12" of the Psyker, that is Standing and is not Engaged. That fighter immediately becomes Pinned.”)
  • Psychoteric Whispers - Opprobrius Curse (“That fighter immediately makes a Toughness check. If this check is failed, the fighter immediately suffers a Flesh Wound.”)
  • Spyker - Psychic Assault (“If the check is passed, the fighter is Pinned. If the test is failed, the fighter loses 1 Wound and is Pinned. If this reduces the fighter to 0 Wounds, roll one Injury dice and apply the result.”)
I'd argue that Crush should not be considered a ranged attack mainly because if it were then people would get a save against the Injury roll it causes, which would be counter-intuitive given that it requires the target to have successfully saved to cause the roll. I doubt the intention is for the target to successfully save thus suffer an Injury roll unless they successfully save again.
Assail is a bit of an odd one as the initial BS test causes a hit but the hit results in moving the target and pinning. If they move into something else then the impact causes another hit with the Strength, Damage and AP given. So the power can do all things expected of a ranged attack but split over two separate 'hits' neither of which individually follow all the steps listed for shooting.
IIRC the hit caused by Suicidal Embrace uses the profile of the target's melee weapon so it's definitely not a ranged attack, it's a close combat attack made by the target.
Powers that say they pin the target under certain conditions, e.g. Force Blast, wouldn't be ranged attacks as otherwise those conditions would be redundant. In the example of Force Blast, fighters that collide with impassable terrain or reach a ledge and don't fall off (due to passing an Initiative test) are stated to be placed prone but it wouldn't need to say that if it were a ranged attack as then all fighters affected by it would be placed prone regardless of where they were moved to.
I understand your points except the first one. I am genuinely confused by it. Will you be so kind as to provide an example?
Not being sarcastic at all believe me. Also happy new year 🪄!
Happy new year!
Due to attacks that bypass the normal to wound roll and inflicting damage process and go straight to Injury rolls (e.g. attacks with the Toxic trait) the shooting rules were changed a while back to allow a save not just if a to wound roll is successful but also if an attack causes an Injury roll to be made for any reason (with exceptions for attacks that explicitly disallow saves such as Gas).
If Crush was a ranged attack and thus caused pinning as ranged attacks do, then it would follow that armour saves were also allowed if it causes an injury roll when resolving the hit.
This would mean the process for resolving Crush as a ranged attack would be:
Declare the action > take Willpower test > select enemy fighter within LoS and 12" as the target > roll to hit using BS > target is pinned > the rules for Crush replace the normal to wound roll/damage, instead the enemy fighter makes a save roll and if successful an Injury roll will be made > back to normal rules for resolving hits, if an Injury roll would be made the enemy makes a save roll and if successful the Injury roll is not made.
The FAQ has confirmed that the intention is for Crush to be more dangerous to heavily armoured targets and this is why the Injury roll is made if they pass their save, thus it would be counter-intuitive if it followed the normal rules for an attack and allowed a save against the Injury roll. To me, this implies that it is not a 'ranged attack' and doesn't follow the normal rules for attacks/resolving hits and instead only follows the rules in it's own description, thus it does not cause pinning as that is not in it's own rules.
