I don´t read that in the Ash wastes rulebook (p 77). The first paragraph says that "when making a ranged attack with a weapon that has the blast (x) trait, a model may target a point on the battlefield instead of an eligible target".
The following bulletpoints on that page stablish how to do that. 3rd bulletpoint says: "make a HIt roll as normal". On a hit roll, you normally apply modifiers. So if you center the blast template on a model that has a cover modifier, you should apply it. Only if you target a point in the battlefield, that can´t have cover or any modifiers, you shoot at your BS. At least that´s how our gaming group has been using the blast weapons, you have less chances to hit directly because of modifiers if you center the template on a fighter, but the scatter has more chances to actually touch it.
