Numbers
MusingWarboss
Oct 31, 2013
5,758
13,215
203
Thinking of getting into BB soon, just wondering though if the numbers on the players mean anything or not. Like are they representative of positions, substitutes etc? Or is it just whack any number on any player for rule of cool?
I’ve not got or read the rules yet but may end up buying a box of models to build soon.
You can have a maximum of 16 Players on the Roster.
And ofc. it's useful to have a number referencing a mondel to keep them apart with no ambiguity.
Most people stick to 1-16, but there is no hard reason you could not have a "Lucky 99" or something.
Also, most teams usually don't want 16 folks on the roster (as this would bloat the team value which is the base for underdog bonuses), most are more then happy to stick with 13 or so.
Rosters have 1 line per player (just like Necromunda rosters) and they are numbered. Each model is a character of its own, which needs to be mapped to the roster. This is can be done with numbers or name. For Blood Bowl, it is a tradition to do it with numbers. You can use any system you want. As a side note, in competitive/tournament play, it is common to use rubber rings to identify who has which skills, and then you don't need any numbers (or names) at all! It's also a convenience when randomizing a player on the team (D16).
Ok, that’s cool. I just didn’t want to stick a number on a blitzer only to find it’s reserved for linemen or something.
It's a form of identification, like names. You can use what you like. Indeed, you could use letters instead of numbers if you wanted (it would be unconventional, but would work just as well). The only thing not to do is having two of the same number.
Yeah, I think I've seen something like that in the great Outside. Was a team of sorts... Like a... a sports team! That's it.
Reactions: Grimfang
That’s my point dude, in Football (soccer) the numbers relate to on field positions or being in a team, b team, reserves etc.
Just checking that there isn’t a similar system for Blood Bowl (probably) based on American Football rules (which I don’t know).
Like Star Players always take numbers 2-4 or Linemen are usually assigned double digit numbers or something.
Reactions: MedMos
There are probably some systems. I like to give big guy nr 1, then have the top positionals follow with line at the end. Surprised that some put top players at bottom, but to each their own. Then I like to overthink and overcomplicate things, so unlike what @Ben_S suggested above, I do have multiple players on the same team with the same number, but usually not at the same time and certainly not of the same position!
For example with humans, I have excess amount of line player models:
NrPosition (primary)Position (secondary)
1Ogre
2Blitzer
3Blitzer
4Blitzer
5Blitzer
6Catcher
7Catcher
8CatcherLine
9CatcherLine
10ThrowerThrower
11Thrower
12Line
13Line
14Line
15Line
16Line
Yes, thanks to awkward amount of players from GW & FW, I have 3 human throwers... Also needed 2 booster packs to complete the team (expensive!), but I already had 2 human teams (also expensive!) because one is plastic and then FW released an alternative human version back when there was nothing more to buy than 2-3 teams (think 2016 had humans, orcs and skaven, unlike the massive amount of stuff we got now). So at least I was able to split it out unevenly, one team having 2 catchers and the other 4.
It can be fine if you know you'll never use them together, but easier to just avoid it. You don't have to stick to 1-16.
I have an elf team that can be any kind of elves, with full positionals and plenty of linemen, so there are 24 models and they're numbered 1-24. Obviously, I'll never be using 24 at once, but my twelve players might still include a #24. It seems easier than worrying about which of my two #10s to include.
Of course, I know I'll never use the Catchers at the same time as the Witch Elves. I guess I could have duplicated numbers on those, if I'd particularly wanted to keep the nuumbers down. But there's no need to do so, so I didn't bother.
Like has been said earlier in the thread, the numbers are used to identify players on the roster sheet and also used when you need to randomly select a player. Most players use 1-16 because you can randomly select a player simply with a single roll of the 16-sided die (D16). That being said, give them whatever numbers you want, just make sure there is a way for you to still easily identify your players and that you have still have a viable method for any random selection you may need to perform. My Nurgle team's Rotters (the basic linemen) are numbered 1-6 and then any other player (the Bloaters and Beastmen, all of whom I imagine are more favoured by Nurgle) are numbered with multiples of 7 (7, 14, 21, 28 and 35). The models are painted with these numbers, but I have added the numbers 1-12 (as that's the amount of models in my team) on the underside of the base. This means a random selection is as simple as a single roll of a D12.
Are you all using the transfers or just freehanding the numbers?
Yes. To both. Not on the same team though.
I like transfers but only if they come with the team. My Chaos team got hand painted numbers because I didn't have any transfers. My Chaos Dwarf team I'm currently working on will be the same.
All mine are free handed. I think for some of my early teams I attempted a logical number progression…. Maybe? I know my Undead team has numbers that are all over the place.
I tend to group positionals together and then just number in order.
Big guys (trolls, ogres, treeman, etc) will all either be number 1 or number 16 as I will use them across multiple teams and it’s useful to be consistent with them.
I also usually number lineman from the last available number down. It’s just a habit I have gotten into as they also occasionally serve double duty (goblins play for black Orcs, goblin teams and underworld teams so end up using the same numbers on each team).
The main thing to remember though is that numbering models has an actual real life use so you know which player is which so whatever you do make sure you can see the numbers from the front and the back as you will be turning them around a lot and it is helpful for both you and your opponent.
I personally paint the numbers 1-16 on the front and back of the bases as it is relatively easy to see for everyone.
Ok, soccer (and Rugby) are just mobs running around randomly. Don't try to pretend they have positions. REAL Football does have positions (Quarterback, Half back, etc.), and numbers like 0-19 for quarterbacks. Which of course, has NOTHING to do with Blood Bowl. In my league, only myself and one other coach have ever even been to a RL football game. The rest never played in a kid's organized football league (MY glory days!), never saw their friends or sibs play, never went to high school games (I was too slow and really only lacking both talent and desire), or college games(hah!), or any pro game. Probably never watched one game on TV, or got invited to a Superbowl party (OK, at the parties, my wife hardly watches the game). None of which is relevant, but where do we get such men?
What is relevant to BB is a way to identify each player in their identical uniforms. Typically, the model is modeled after its position (Throwers modeled throwing a ball). Which is why positions don't have a designated range of numbers. But, to keep track of players for league purposes (advancements, injuries), numbers do the trick. Either decals, or sharpie numbers on the base.
