Hi, so I never played Necromunda but I plan to soon.
I'm building a gang right now and I'm at the point where I need to decide which hands to stick on so I thought I'd build a roster first.
A friend told me I should leave at least some credits in case I need to heal gangers after the first fight, so I saved 20 for it.
The big question is do I really need the Heavy Stubber at this point? I feel if I freed up points to get at least 1 or 2 more guys (preferably some Autoguns too) that would be better.
A couple options I have to do that are:
- Get a second Shotgun Arms Master instead of the Road Sergeant. I used up my second Arms Master mini to make the Leader though. And in general, I feel the two Arms Masters would have to be very similar, because Shotgun Savant just seems too good, too appropriate for them. That's a bit of a negative in my mind.
- Get the Sergeant a stub gun to cheap out and call it a day, buy the Stubber later.
- Get the Sergeant an Autogun, maybe even with a Telescopic sight, to be able to use the Bullet Lord, buy the Stubber later.
But I feel like I'll really miss being able to A) lay down heavy damage in one activation without having to run up into someone's face and B) simply being able to reach far out targets like Snipers (since everything that shoots further than 24'' in Orlocks is a Heavy Weapon).
What should I do?
What should I do?
