N18 Outcasts - Reality Check needed :D
Rokksville
Jun 3, 2021
10
6
I have a plan. It is not be the best plan to keep friends, it's not a good plan, but it is a stupid plan that would match the lore I have in mind and I want to know if it’s „legal“ RAW.
I am currently considering to kitbash a melee focussed Mutant Outcast gang and came up with this idea:
- Intend to use Gorshiv Hammerfist elevated to an Outcast Leader as outlined in the Book of the Outcast
(I would only use his stats and rules, but would use a completely different model. Rules and Equip just perfectly matches the idea I have for this leader.)
- Giving him either Clanless or Criminal organisation Affiliation
- Giving him the MUTANT archetype – without giving him any mutations to start with, because otherwise I would lose his other skills and equip, am I right?
- Now I got a chunky Melee Mutant leader that I wand, and theoretically this should open the possibilites to give my Hive Scum a single mutation each
Would love to hear if this is how things work, as the Outcast rules are a bit complicated to fully understand, especially for a non-native speaker.
Thanks in advance :)
Chief complication I see is with the "or Criminal organisation Affiliation" but, fairly sure mutants can only have clanless, sadly.
Ah true, reread and you’re right. That’s fine, I was more concerned about how Hammerfist might work with the mutation part
Thank you
Elevating a fighter says to choose an Archetype, but also that you can either keep their own skills and equipment and special ruies, or gain those of an Outcasts Leader. It looks as though you have it right - taking a mutation would replace his skills and equipment and special rules. The Archetype then gains special rules for the Outcasts Leader of its type, but skills and equipment [such as mutations] have already been fixed.
The special rules being Gang Hierarchy, Group Activations, and
A Mutant has access to the following skills:
Brawn Primary, Ferocity Secondary, Leadership Primary
In addition, Mutants can also choose Outcast Mutations in place of skills (see Outcast Mutations on page 7).
Furthermore, if the Leader of an Underhive Outcasts gang has the Mutant Archetype, then Outcast Mutations
will also be available to Underhive Outcasts Hive Scum in their gang.
... Underhive Outcasts Leader that takes the Mutant Archetype can only have the Clanless Affiliation.
So as they gain Advances, they could buy mutations over time, as [Primary?] skills. And the Hive Scum of the gang can buy one Mutation each on hire. I think you have it sorted, aside from the Must Be Clanless.
Thank you! Yep, the Clanless thing was my mistake of not reading it properly. :D
I'm running a similar gang right now. I'm using the Mutant Ogryn as my leader, swapping its abilities and weapons out for the Horrific Appearance mutation.
It's fun to have a big boss monster, but the rest of the gang kinda sucks. The champs are just ok, and the gangers are below average with terrible mental stats.
Random selection scenarios will ruin your day if you don't draw your leader.
Mental stats rarely come up and thier other stats are just a average. Somebody has to be average.
They have good Trade Post access though. Shatter shell shotguns on mass with a bullet merchant work great.
I
Dunno what you're playing but mental stats come up all the time for me. The only one that's rarely used is Leadership. These guys run away from a scary noise, and can't open doors & caskets more often than not. Even worse in Underhells where there are a lot of Intelligence checks for data crystals and objectives!
