I have a few questions regarding using vents and tunnel in the Outlanders sceanrios. As stated in the NCE rules, you can use special deployment unless it is explicitly stated otherwise. Now this is very explicit and consistent in the NCE Rules, but not so much in the Outlander rules. Only the Hunters Scenario states explicitly that special deployment cannot be used, in the same manner as seen in NCE Rules.
For the Caravan, Loot & Pillage and Heist scenarios I see no problems in allowing the use of vents and tunnels, but I might be wrong about this?
And for The Hit I feel that it gets a bit more complicated:
The Hit (Attackers): "All the attacking fighters must be set up behind cover and hiding more than 16" away from the opposing leader".
-- Now if all the attacking fighter are doing this, then i guess none of them are using vents or tunnels?
The Hit (Defenders): Divide into groups. Either the groups are not deployed, or they specifically have to be set up 12" away from gang leader or 6" of the gang leader.
-- deploying 12" away from leader could be in the vents or tunnels?
On the one hand I feel that the deployment rules are telling me that special deployment cannot be used, but on the other I feel that that rules for deployment so far have been consistent and explicit in telling me when you can use vents and tunnels and when you cannot.
So how are you usually doing this? Looking forward to hearing your replies, thank =)
