Print and play tiles
Biggle_Bear
Nov 1, 2017
1,902
3,129
218
This guy does loads of print and play terrain that I think look awesome and I want to make for dungeon crawlers.
I thought I would post a link here.
Much appreciated. Tiny trees and other outdoor videos should help solve some of my 15mm terrain needs.
To follow this, I believe the same guy is listed on DriveThruRPG if you wanted to pay for stuff (not sure if paid stuff is in the link @Biggle_Bear shared, and there is also PWYW and free stuff):
Yep. Bought the tiny trees and a few other sci fi files. Initial attempts to find the patterned scissors from his YouTube video for the trees have not been successful.
I have only played WHQ95, not the modern ones… but the magic is to randomly generate the map using a deck of cards. Are the pre-built maps a good idea even if you do not use a DM?
I understand that part of the fun is not knowing what you will find at the other side of the door…
Does anyone had a good experience with these maps in WHQ?
