Recruiting Chaos Cultists - any advice?
jonbo
I'm building a new chaos cult for an upcoming Dominion Campaign and have drafted the following 1000 cred starting cult.
Demagogue - sword, autopistol, grenade launcher
Disciple - heavy stubber, reclaimed autogun
Disciple - chainglaive, autopistol
Witch - Assail, club, autopistol
Cultist - long rifle
Cultist - hand flamer, axe, reclaimed autopistol
Cultist - autogun
Cultist - autogun
Cultist - autogun
Cultist - autogun
Feedback welcome!
Reactions: ThreeDice and spafe
I like you list a lot. I've found a long rifle on the disciple to be super handy and reliable to back up the heavy weapon disciple. Everyone seems to focus on the heavy to their demise lol. Personally i want to like the chainglaive for the rule of cool but have more success with flails, which are still cool but not the same as running around with a beefed up hedge trimmer lol.
I'm running Chaos in a Dominion Campaign at the moment although I built my gang prior to the rules update, which meant no Long Rifle or Grenade Launcher and expensive CC options.
Your list looks much stronger than mine did but temper your expectations of competence, especially against Goliaths. My gang felt like the bad guys in the A team a lot of the time, spraying bullets everywhere and damaging nothing.
I've actually shifted the rank and file towards close combat a bit more, Smoke Grenades are cheap and Common, and you can overwhelm better quality gangs.
I think the Heavy Flamer is a little bit underrated. I've had a lot of success with mine, more so that the Heavy Stubber. He gets more value out of having a flunkie nearby to open doors and suck a hit. Also I think you'd get more value out of Flak Armour than a backup weapon on the Heavy Stubber.
Thanks for the thoughts folks! I'm starting up the campaign on Wednesday so it will be interesting to see how it runs. I've already put together a second long rifle ganger and a disciple with a missile launcher in the hope that I end up with some creds to spend!
@Fassbinder75 - interesting observations. I am only expecting one Goliath gang in the campaign (Escher and Van Saar seem the Houses of choice for most people). My main issue with the heavy flamer is that it is tricky to use without Overseer or suspensors. A static template weapon strikes me as just too cumbersome in most circumstances.
I'd only add that the Witch has really low in-game use.
I find the 5+ BS and WS really doesn't make you want to take the shots, and (as you've pointed out to my eternal sadness) the psyker powers are so sporadically useful.
I've got 2 campaigns going at the moment
- In one he's a backfield buffer/injury man. Gave him Dark Shield, no weapons, and a Medicae bag, plus first skill up he's got is Fixer (as he generally survives).
If I need to arm him i'd give him a flamer next.
- The other campaign I did give him scouring, and so coupled with the boss with Overseer he can be fairly surprising, however its still only a flamer and he does not excel yet.
Next time, I'm going with the backfield buffer build, will probably give him flight.
Your leader is a combat beatstick similar to mine (flail, axe, autogun, mesh armour and nerves of steel) but grenade launcher is a good option, as its the same price as the Goliaths.
What skills have you gone with on the Disciples? Evade on Heavy Stubber I'm trialling with some success, and Infiltrate on your melee boy may work nicely with the Chainglave if you're set on it? Otherwise I'd echo Zae55 and get another cultist with Mesh armour and an autogun for that price! Go shotgun + infiltrate instead?
I'm running a long rifle disciple with Evade, and he's saved my behind a few times (while shrugging off some serious firepower). I'm waffling on which skill to take next, though Overwatch would make the denial game better. I finally gave him another long rifle buddy to activate with, and that backfield firebase helps my mid/short short range stuff step in.
If I need to roll my crew again I will take a witch with almost nothing and just dark shield the backfield firepower. Even with a familiar, getting close enough to hit with scouring or the other close powers is dangerous as hell for one of your money-makers.
What are yall using for the models? I had thoughts of kit bashing genestealer neophytes with cawdor weapons. Is there an easier, or more interesting way?
You may find a regular cult member and a head from a GSC neophyte/Delaque sprue may be an easier/cheaper/more fitting option, I don't think the hazard suits on the GSC models really fit with a witch image.
