Hi!
I'm going to play a "Rescue Mission" soon against a Cardow gang and I will be the attacker. According to the scenario rules, the defender can play Tactic Cards only after the alarm was raised. Given the other player draws the Tactic Card "Apostates" (play before deployment, gain 3 additional Bonepicker, can exeed the starting-crew size in the scenario). Can that card be played somehow (maybe after the alarm has been raised - or before deployment) or is it basically useless in this scenario?
So basically: Can Tactic Cards that are played before deployment be played in Rescue Mission, by the defender, before the alarm has been raised?
My interpretation is that the card cannot be played (by the defender) because before the deployment the alarm is not raise and when the alarm has been raised it is too late to play the card.
In the sense of fair play I would allow the other player to redraw or to play the card after the alarm has been raised and add the Bonepickers to the reserve.
How do you see it?
How do you see it?
