Question Sanctioner Automata on YakTribe
Toffer
Jan 1, 2016
234
1,026
108
Blenheim, NZ
Hey Underhivers
quick question
is there a way to add Sanctioner Pattern Automata to a gang on YakTribe please? I cannot see it in any of the drop down menu's when I try and add it to the gang.
As of this post, the sanctioner automata hasn’t been added to the tools as a universal template.
You can make one yourself though, using the custom fighter tools. I made a rough guide on making mastercrafted weapons , the process of which is transferable to the custom fighter tools. Just replace any references to custom equipment with custom fighter and you’ll be just about there.
The main difference will be that the fighter profile template will be in the drop down for hiring new fighters. Have a play, you’ll get the hang of it.
im being dumb, i can add the automata, but i cant add equipment to it?
im being dumb, i can add a sanctioner pattern automata & add to my gang, i can even select skills for it. but it wont let me select equipment for it? presuming i need to build all custom gear for him anyway, but would have assumed things like armour i could select?
You may need to switch equipment restrictions off in the options menu and you’ll have every piece of equipment available to choose from.
thats the one! how about special rules? any way to edit those fields?
Unfortunately there isn’t a way to add or edit special rules, apart from adding them to the fighters notes- I don’t think the notes print off on the fighter cards though, so that may not be the solution.
cheers
how about adjusting the starting gang credits? seems to default to 1000 credits, im in a 1500 credit skirmish - can i up the starting amount?
SIMILAR ISSUE HERE:
I have successfully added the Automata to my Enforcer player's list of model options, and have created custom weapon profiles for that model's weapons. (i have also removed weapon restrictions) It is allowing me to select weapons for the Automata now, however, the custom weapons I created are not listed as options.
Reactions: Kliklaklut
SIMILAR ISSUE HERE:
Hi, trying to do the same here, anyone knows why the custom weapons created are not showing up in the equipment list ?
Thanks !
Thanks !
SIMILAR ISSUE HERE:
Once you have made your weapon stat lines, make sure you are then going into the custom equipment tab to actually create the weapon, choosing the statline you just made in the custom weapon section from the stat drop-down menu
If you just made the statline in the custom weapon tab and didnt do anything in the custom equipment tab then your custom weapon exists as stats only and not as an actual equipable item
when in doubt follow the guide posted earlier in the thread
